Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-18-2008, 12:34 AM
EX40 is starting off with a positive reputation.
Hub assembly removal - having issues:(
Yes I searched extensively before even tackling this project. Got the hub out fine, removed the nuts behind the spindle. I've tried banging on it, 3 jaw puller & can't get it out. It's started to separate but one bolt is just stubborn as hell & won't break free. What else can I try? My next idea is to take a cutting wheel to it & get new studs. If its this bad I don't see them being any good to reuse anyway. Any suggestions?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-18-2008, 08:08 AM
Wilson & Co is starting off with a positive reputation.
if you didnt strip the bolt then heat it up with a torch
  #3 (permalink)
Old 06-18-2008, 09:04 AM
neilc88's Avatar
neilc88 is starting off with a positive reputation.
Try putting the wheel back on and hitting the wheel with a sledge hammer to break it free. That's what I had to do.
__________________
2002 X, 4x4, Limited Ultimate, 285 Revos, Bilstein shocks, Edge mini-spring kit, F-350 4" rear blocks, S.S. speed grill, Lund trim color deflector, Hellwig rear sway bar, tinted windows, Sure-Drain.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
