Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Might try a pull: Old Ford vs. new GM
Old 04-22-2008, 09:29 PM
gweeds's Avatar
gweeds
gweeds is offline
Question Might try a pull: Old Ford vs. new GM
So a buddy and I might try to pull against each other, and I was wondering what you guys think. I've never really been into competition at all, and know nothing really about how these engines/drivelines stand up against each other.
Mine: '94 f250 4x4 e4od 7.5L
His: '07 gmc 1500 4x2, 4-spd (?), 5.3L.
Am I just going to get embarrassed?
Old 04-22-2008, 09:45 PM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl is offline
Just stand on the brake till he starts to spin then pull him away. Your 460 should have no problem doing that. Throwing some logs our something in your bed wouldn't hurt either. You could use your 4wd for some extra insurance, just dont say anything about it.
Old 04-22-2008, 10:44 PM
gweeds's Avatar
gweeds
gweeds is offline
So... What you are saying is that the GMC can't pull 5000# of dead weight?
Old 04-23-2008, 07:31 AM
thorseshoeing's Avatar
thorseshoeing
thorseshoeing is offline
decadent and depraved
You probably have the weight advantage, so you should win...
Tim
Old 04-23-2008, 07:59 AM
BigF350's Avatar
BigF350
BigF350 is offline
and the 4x4...
2nd gear low range, Brake, stall it up, till he looses traction, release brake, and wham.
Oh, and did I mention "pull offs" can be dangerous. Keep your head low for a flying hitch through your rear window...
Old 04-23-2008, 12:22 PM
SANDDEMON08's Avatar
SANDDEMON08
SANDDEMON08 is offline
I see your truck is 4x4 if its a little higher hook short and when to pull you will gain load on your rear tire and he will lose load on his thus giving you a good advantage. I few years back i got cocky and a older guy with a lifted gasser put the whoop down on my 7.3 PSD and explained this simple advantage to me.
Old 04-23-2008, 12:25 PM
less's Avatar
less
less is offline
It will be down to which truck gets the most traction. Your 460, even though old has2 1/2 liters of displacement over the chevy 5.3...but I think traction, not torque, maybe the deciding factor.
Old 04-23-2008, 06:54 PM
Not saying that. Just saying your 460 could easily do that. Like mentioned earlier traction is the key.
Old 04-25-2008, 01:15 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is online now
Received 2,739 Likes on 1,330 Posts
If I could get the traction, my fourwheeler would outpull your F250
Put yours in 4-Lo, 1st gear and ease on the throttle once the signal has been given. Your automatic is already a HUGE advantage over his manual. Plus, your 4WD pretty much guarantees a win.
Don't forget to lock your hubs!
And if he gets Butt-hurt about using your 4WD...they tell him to forfit.
Old 04-25-2008, 07:53 PM
gweeds's Avatar
gweeds
gweeds is offline
Ha ha thanks everyone. Going to try it sometime in the next week or so, depending on the weather. Ill post a video/results when it happens
Old 04-26-2008, 08:52 PM
RDJ184's Avatar
RDJ184
RDJ184 is offline
dont punch it ..let him hang him self...there is a little skill involved...film it
Old 05-02-2008, 09:14 AM
tjthegreat's Avatar
tjthegreat
tjthegreat is offline
i believe the 460 has more torque than the tundra so ur good in that department.and all i hear about chevies is how u have to rev the crap out of them to get any power
Old 05-05-2008, 06:01 PM
F250Wildman's Avatar
F250Wildman
F250Wildman is offline
The F-250 will kill the 1500 Gotta Mechanic Coming.
Old 05-06-2008, 07:27 AM
toddol1971's Avatar
toddol1971
toddol1971 is offline
I think these kind of pulls are STUPID. They prove nothing. Go grab a travel trailer or flatbed & put 5 or 6k in it & time a run up a hill somewhere. Use a third person to do the timing & signaling. He will lose. I had a 5.3 & they suck @ towing. Now if he was to drag race you then you will lose. See your both even, no need to do anything now lol.
Old 05-07-2008, 12:17 AM
gweeds's Avatar
gweeds
gweeds is offline
Well, thats true... If you compare, lets say the 460 to the 454, you have to rev the 454 about twice as high to get the same power. They are just designed differently. For towing though, its better to have the power in the lower RPM range.
And hey, I'm young and reckless... We do these things...
Quick Reply: Might try a pull: Old Ford vs. new GM
