Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-17-2008, 09:19 PM
MAKO314's Avatar
MAKO314 MAKO314 is offline
Garage is empty, add now
MAKO314 has a good reputation on FTE.MAKO314 has a good reputation on FTE.
Clear biodiesel????
I have made biodiesel that is still a bright amber and crystal clear. my question is , is there a way to make this stuff clear and take away the amber color or is that color just the nature of the beast.
__________________
Ashley
2000 F250 Destroked "Frankinstien" CR 5.9 Cummins 631 HP 1389 lbtq
2003 explorer limited AWD V8
1990 7-UP mustang 5.0
  #2 (permalink)
Old 06-17-2008, 09:36 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
I heard the color is a result of the oil that you use. Different oils; Soy, Canola, Corn, olive will produce different colors.
Crystal Clear - are you dry washing?
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #3 (permalink)
Old 06-18-2008, 02:49 PM
MAKO314's Avatar
actually no, I'm water washing with a fine mist for about 30 min and then for about 20 min under high pressure then I heat dry the fuel for about 8 hrs at about 150*. this produces a bright amber yet clear biodiesel.
__________________
Ashley
  #4 (permalink)
Old 06-20-2008, 04:13 PM
BioBurner's Avatar
BioBurner BioBurner is offline
BioBurner is starting off with a positive reputation.
The amber color is no problem at all. It is just the characteristic imparted by the oil feedstock.
  #5 (permalink)
Old 06-20-2008, 07:06 PM
adambomb's Avatar
adambomb adambomb is offline
2005 Ford F-350
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
in my 3ish years of using biodiesel i have seen bio in almost every color except blue or purple.
__________________
2011 Escape Limited v6 (Loaded) ESP 7yr/65k and Full Ford Maintenance Plan
2005 F350 6.0 (modded) ~450rwhp/900+ft/lb tq
1999 F350 7.3 (normal mods + 13" King Suspension on 40's)
1998 F150 (basic mods + 7" Suspension on 35's/Prerunner fiberglass and skidplace)
1994 Bronco (normal mods + 9" Coil Suspension on 35's)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
