Join Our Site - Its free, quick and easy!
Click Here to join.
06-17-2008, 07:13 PM
05 Wheels on a 02 X
Will f250 wheels work on an 02 X? I found a good deal on a set of wheels and tires w/ 285-70-17. They are the solid 5 spoke alum. Anyone have pics of this setup if it does work? Mine is a 4x4 but I dont have any lift. thx
Sponsored Links
To remove this ad, register today!
06-17-2008, 07:52 PM
Will a spacer work and be safe?
06-18-2008, 12:03 AM
Sit. Stay. Become a
Spacers will work fine so long as you get HIGH quality, HUB-CENTRIC spacers.
I got mine for wheeladapters.com. Fred knows his stuff and makes quality products.
2" is what you want. You can go 1.5" but you'll have to grind down your existing lugnuts a bit or the wheel won't mount up. 2" puts them flush to the wheel wells.
__________________
Ken
05V10
I love cats.
...but I can't eat a whole one.
06-18-2008, 12:06 AM
As long as it stays within the factory specs, you'll be ok. Monsta had to do it on his '05 when he put '08 20s on.
__________________
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
Sonnax/Tricumulator kit
V10 Trans Cooler
Power, Heat, Lighted, Signal TT Mirrors
6 inch PROcomp lift
315/75/16 BFG AT K/Os
9007 Bosch HIDs
4.10 Gears
WW
06-18-2008, 12:08 AM
Monsta, you crafty night owl, you beat me to it!
__________________
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
V10 Trans Cooler
6 inch PROcomp lift
9007 Bosch HIDs
4.10 Gears
WW
06-18-2008, 01:50 PM
Quote:
Originally Posted by
Toreador_Diesel
I'm begining to think he has this site somehow hooked to his thoughts and can navigate and reply to posts as soon as they go up
But hey if it helps us out...
__________________
Early'99 V10 SC SB XLT 4X4 / 7" lift / Factory '08 Lariat 20s / '07 front end swap / '08 rear Lariat bumper / H.D. paint scheme
Soon to come: / HD Leather / wood grain / 4.56s / 37s
06-18-2008, 03:48 PM
Sit. Stay. Become a
The post had been up for almost 4 hours before I responded. I was actually thinking I was losing my touch.
__________________
Ken
05V10
I love cats.
06-27-2008, 03:22 PM
Just adding my .02 cents here.
I was thinking about using 07 f250 rims on my 05 X and had the same problem as you - wheel offset.
I looked at hub centric spacers and they were over $100 each. This added $400 to the cost of a rim & tire package that was well aboe $1500.
I bought 18 inch Ford SVO rims on Ebay that have the correct offsetfor $625. 4 Nitto Terra Grappler tires for $800.
I spent $1425 and have brand new rims and tires. I also sold the old rims and tires for $500 on ebay so my true cost was $925.
And no spacers.....
06-27-2008, 07:13 PM
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
