buss on the wiper switch is worn in "closed loop" connection. This happens change switch out.
Good thing you said ignition was ok. The tumblers wear out early from to many keys (large weight) hanging from key. weight down-end of key up-bad end result.
Belt size? Just take a simple material ruler. It is like string. wrap it around the belt. You can have an offset either way by about an inch.-Good Luck
__________________ 1994 Extended Black Sport 4.0 2 wheel drive 1994 Extended Blue/gold 4.0 Eddie Bauer 4 whl-drive 1993 Extended Blue/gold 4.0 Eddie Bauer 4 whl-drive 1992 Shorty Blue 3.0 2 wheel drive +1989 Extended Red 3.0 2 wheel drive ="5ive"Aerostar'sP-R-I-C-E-L-E-S-S signed B O Z
wait if you're aero is a two belt system like mine, does it matter the length of the powersteering belt? on my 93 it's the larger surpintine belt that goes through the AC Pully, alternator, and the idler pully.
