2001 Exp 4.6L spark plug change
I have a 2001 Expedition with over 150K miles, and its way overdue for a spark plug change. It still as the original factory plugs in it, runs ok, just idles kinda rough. My plan is to get
them changed next week, and I need a recommendation on replacement plugs. Are the Motorcraft plugs ok, do I need to get platinum plugs? I've also heard that its a good practice to change all 8 coils when you change the plugs. If it is, would changing to MSD coils be a good idea? I've checked on them and the cost is about the same as replacement stock coils from the parts store.
Thanks
Howard
Thanks
Howard
Plugs/Coils
Thanks for the info. I'm able to find Autolite plugs, not much luck finding Motorcraft. Are the double platinums fine, or is there any value in going to the more expensive Iridium plugs?
On the coils, the MSD coils should help a bit with the performance since they are a hotter coil?
Thanks
Howard
Thanks
Howard
Motocraft double platinum for stock, iridium if you're tuned, but at 4.6L i doubt you're tuning. DON"T change the cop's. You run into more chance of fowling something up. Change the boots, make sure to use dielectric grease on them thoroughly. Only change cop's id one dies, then change them all at once, not one at a time, from ebay, not Ford. Happy changing
Thanks
i am going to give these cheapy's a try for my 03 5.4 expy. wish me luck
eBay Motors: NEW IGNITION COILS 97-05 FORD EXPEDITION V8 DG508 (8) (item 120373823302 end time Mar-06-09 14:56:05 PST)
TomBrooklyn2
02-05-2015 05:51 PM
jrw51
1997-2006 Expedition & Navigator
08-18-2009 11:46 PM
