Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-17-2008, 02:29 PM
MeanMan66's Avatar
MeanMan66 is starting off with a positive reputation.
'71 to '66 disc swap??
New owner of '66 F250 C/C C/S. I've been reading here for a couple of months now and would like to thank everyone for what I've learned thus far.
Reading past posts regarding disc swaps, '73 to '79 donors are mentioned as appropriate. I recently bought a '71 F250 rolling chassis mostly because I couldn't pass up the price. Useable rear chrome bumper alone justified the purchase.
I had already started to overhaul the front drum brakes, but now am considering swapping for the disc. The chassis has dual piston front disc.
Has anyone used a '71 setup?
'66 now has power brakes w/ single pot. What issues do I have with fitting a dual pot M/C to the existing booster.
Any help or opinion regarding swap / no swap would be appreciated.
Thanks.
PS can anyone estimate labor hours to perform swap? I know thats a hard one but I'd hate to see the truck sitting in the garage for half the summer. If this is the case I might just finish the drums and tackle the discs this winter.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-17-2008, 02:48 PM
bigblockford_390 is gaining momentum as a positive member of FTE.
When you have read about using 73-79 parts as a donor, that is mainly for half ton pickups. Sometime in the late 60's on F-250 pickups you could get front disk brakes as an option, but not on F-100 until 73 and then it was standard.
I would think your 71 pieces would work just fine, just like the articles you have read, use all the parts from your donor and the swap will happen very easily. I did mine on a F-100 in a weekend.
Jeff
  #3 (permalink)
Old 06-17-2008, 05:57 PM
jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.
If you want to convert to a 250 then go ahead, the parts will not work with a 100.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #4 (permalink)
Old 06-17-2008, 10:18 PM
Quote:
John
He already has a 66 F-250 so why would he need to convert?
Jeff
  #5 (permalink)
Old 06-17-2008, 11:13 PM
ddavidv's Avatar
ddavidv is starting off with a positive reputation.
jowilker is a believer in swapping out the entire front end. I've done it both ways and prefer the spindle swap via the kingpins. Either version you can easily do the 'hardware' in a weekend. The master cylinder should work fine with the booster provided the bolt pattern is the same so it fits and the pushrod length is correct or modified to the same length as the single pot.
The brake lines are the most time consuming, mostly because you have to make them from scratch and can't just copy what's on your truck (adding the proportioning valve adds to the fun). I'd say a week of evenings would do them. I left the stock ones on from under the front floorpan back. There is a junction there you can easily tap into.
The whole process is a couple of weekends if you work that way, provided you get all your parts up front! The front suspension portion requires some muscle and floor jacks and the brake lines require patience and endless trips under the truck until you get them right, but none of it is difficult work.
__________________
'65 LB Custom Cab 352 3 spd.
  #6 (permalink)
Old 06-18-2008, 01:45 AM
sllt96xlt is starting off with a positive reputation.
i plan to do the same swap. i have a full 72 donor to swap into my 65. not sure how long it will take me, i'm not in a rush. i will probably start next summer. i plan to do p/s at the same time too.
__________________
1965 F250 Custom Cab
1972 F250 XLT Ranger, to be donor truck.
  #7 (permalink)
Old 06-18-2008, 07:25 AM
Quote:
Jeff
My bad, I fast read these post and the 250 part didn't take.
John
__________________
  #8 (permalink)
Old 06-18-2008, 01:13 PM
MeanMan66's Avatar
Thanks for info.
Related question.....has anyone fit 16" one piece wheels over the dual piston caliper
The 66 came with 16" splits with 7-50's which I was going to upgrade to a one-piece wheel to run radial tires presumably 235/85
Donor chassis has 16.5" wheels - kinda oddball for tires and I don't know if I can go as tall/skinny as the 7-50's with a 16.5. Closest I know is 9-50's roughly 1" shorter and 2" wider.
the 16" splits clear caliper so it makes me wonder if a newer one-piece 16 will also clear but not sure about differences in width, backset and inner diameter
wanting a relatively stock utilitarian look so standard plain steel. not wantiing to go to big plus up sizes
Thoughts?
Rich
  #9 (permalink)
Old 06-18-2008, 01:59 PM
PROSTOCK is starting off with a positive reputation.
Yes, I have, there's no fitment problem with one piece wheels and dual piston calipers.
__________________
'65 F-250 Custom Cab 352FE 2WD
PS, PB, C6, 3.73 Dana 61('81 F350)
'02 Excursion Limited V10 2WD
Bilsteins, Tekonsha P3
  #10 (permalink)
Old 06-19-2008, 11:57 PM
winr is starting off with a positive reputation.
On my 65 F-100 single bowl master cylinder the push rod measured 4 3/4".
Measuring from the back of the master cylinder mounting flange to the center of the push rod hole.
My truck has a bolt made like acam to fine tune the brake pedal.
I used a dual master cylinder, cut the push rod to fit and rounded it off.
Richard.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
