My well used 87 ranger needs ign switch replaced. It acted up first by the key not snaping back to the run position. Then yesterday it wont turn at all. The more i tryed to unstick it i seemed to make it worse. Now wheel is locked too.
I havent had a chance yet to open it up yet. How hard is it to replace? If any body has any advice or help id apprecate it. Thanks joe
__________________
2002 F250 7.3 4x4 long bed super cab 6 speed
Replacing the electrical switch is a simple 30 minute job. Remove upper column trim & a couple of "theft proof screws." Vice grips will work.
If the lock cylinder is the culprit, it's also a simple job, but the key has to move to the run postion to release the spring loaded pin that holds it in.
If you do need to replace the lock cylinder, remove the lower column trim, turn the key to run and shove a small screw driver into the hole on the underside of the column. The cylinder will then pull out.
Took the trim off, not what i expected to see! But i got it working by using my very worn old key. It appears that it will work that way. Awhile back i switched to a spare key becasue the original was so worn out. From an electrical standpoint i think all is well. Do you think i should just change the lock cylinder and try that? And im assuming id get a new key with that? Also, those break away bolt heads are too low to grab with vise grips. I guess you will have to drill first? And remove the torx screws that are holding from the other side? Thanks joe
__________________
OK changed cyl lock key, it was any easy change like you said. Now key works well and all the electric is ok. I thought i had it made but when driving the truck if you have to turn the wheel past a point like when parking there is a bump. Im guessing the lock part is damaged. The tow truck driver and myself were leaning on the wheel hard trying to unlock. It was also pulled around abit when put on a flatbed. Im guessing that something else inside the housing is worn or damaged? I dont know but i guess i have to drill out the break off bolts and lookinside where the ing switch is? Id appreciate it if you have ever dealt with this befoe and have any advice. Thanks joe
__________________
