Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-17-2008, 08:29 AM
CrimsonRanger is starting off with a positive reputation.
Angry OD light flashes on and off!
2000 Ranger with 92,000 miles. After I drive for about 10 minutes and then stop at a stop sign, etc, the OD light will begin flashing on/off after the trans shifts into second around 25 MPH when I start driving again. Sometimes this shift has a bump to it, sometimes not. The truck runs and drives fine and OD seems to still be working. I can press the OD button at 60 MPH and feel it kick off, then press it again and it will kick back in. Local mechanic ran codes and the only think that came back was EGR vacuum. Replaced the vacuum hoses, checked EGR and had the trans filter and fluid replaced thinking this might help but it hasn't. The truck cleared all codes at the shop after this work. Don't know if it has anything to do the solenoid that controls shifting inside the trans case or not? What do you guys think? Pulling my grey buzzcut out at the roots trying to solve this.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-18-2008, 01:46 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
The flashing OD light means a transmission fault has been detected. Remember, the computer can detect slippage long before you can, the computer can detect as little as 10% slippage, while you wouldn't notice any slippage till you have around 40% slippage.
when was the last time you replaced your tranny fluid?
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #3 (permalink)
Old 06-18-2008, 02:27 AM
Pablo-UA is starting off with a positive reputation.
Just pull tranny codes with OBD-II reader...
  #4 (permalink)
Old 06-18-2008, 09:17 AM
Bear River
Had the fluid and filter changed about two weeks ago when the vacuum hoses were replaced.
  #5 (permalink)
Old 06-30-2008, 12:07 AM
Tranny codes pulled indicated an incorrect gear 2 ratio and a shift solenoid. ERG valve also.
  #6 (permalink)
Old 06-30-2008, 06:18 AM
codes please! P???
May be you have 2nd gear band sliping....[???]....
Ajusting helps for 10-50k....
  #7 (permalink)
Old 06-30-2008, 12:21 PM
mfp4073 is starting off with a positive reputation.
or a shift solenoid/fluid flow problem. What are the exact codes?
__________________
please do not take any of the above advice as that of an expert!
99 3.0 auto ext cab stepside 4x4
  #8 (permalink)
Old 07-06-2008, 11:35 PM
UPDATE: Ohm tested the six solenoids in the tranny and they seemed good, but thought that one might give trouble when it got hot, so replaced the solenoid for shifting and the one for 1/2 gears; Also replaced a bad gasket around the valve body and this seems to have corrected the problems. No hard shifting, no OD light flashing, and it seems to shift smoother than it did when I bought it. There were no metal filings in the tranny pan so i felt good that there was nothing major going on there. I was also getting an insufficient EGR reading but that seems to have cleared as well.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
