can't hook up aftermarket radio.... - Ford Truck Enthusiasts Forums
Old 04-14-2001, 07:48 PM
blue94z28 blue94z28 is offline
blue94z28 is starting off with a positive reputation.
I purchased an alpine cd player, and a wiring harness for a ford premium sound system for my 97 expediton today, and after hooking everything up, the radio functions but i have no sound to my speakers. I do not have the mach 460 sound system so i had assumed that i didn't have an exteranl amp. am i wrong? All the wiring for the speakers was in the dash and is hooked up properly, yet it seems that i don't have any speakers hooked up. Any input woulp be appreciated.
thanks
Brandon
97 expedition
Old 04-15-2001, 08:28 PM
otto otto is offline
otto is starting off with a positive reputation.
this may sound dumb but is the radio muted or anything ? if not i would take the radio out and try to hook up one of the channels to a speaker that you have laying around it might be possible the deck has a bad internal amp
Old 04-26-2001, 01:33 AM
instigator99 instigator99 is offline
instigator99 is starting off with a positive reputation.
Don't feel bad i also have the same problem, except i have a 1997 Explorer Sport, im getting nothing from my speakers i did a batery test on all the wires and no good. Going to the ford dealer tommorow and see if i can get some help there.
Old 04-26-2001, 02:28 AM
There is a stock amplifier and the only way to get sound is to bypass it, with a truck you will probably have an easier time getting to it mine is located in the rear on the passanger side quarter panel. I am going to add a link for you to go to. I hope this helps.
http://129.186.184.70/explorer/
Ray McMaster
Old 01-31-2002, 03:10 PM
royhuntley royhuntley is offline
royhuntley is starting off with a positive reputation.
I don't know if this will help you much, btu we'll see. I have a 91 Explorer w/ the premium sound and had the exact same problem. on the aftermarket wiring harness there will be a blue "remote" wire. Hook that up to the remote wire on your stereo or to the power antenna wire on the stereo and it should work fine. What's happening is the stereo isn't turning the external amp(yes you have one) on.
Old 02-04-2002, 07:26 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
You may have an amp. Call the dealer to be sure, they should tell you. If so, Metra and Scosche sell amp bypass kit.
Old 02-05-2002, 08:14 AM
Project Project is offline
Project is starting off with a positive reputation.
Stock radio installation Zachthemoo2 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-07-2014 11:30 AM
'87 F350 NO speakers. Hockeymandan 1987 - 1996 F150 & Larger F-Series Trucks 5 09-27-2013 09:12 PM
Speaker/Radio - Issue? great white 2004 - 2008 F150 6 04-24-2010 03:53 PM
97 expy stereo questions. teknochode 1997-2006 Expedition & Navigator 11 11-04-2006 07:48 AM
97 f150 w/no sound schiluck 1997 - 2003 F150 3 10-19-2005 10:15 AM
Tags
1997, aftermarket, didnt, expediton, f150, ford, fords, hook, hooking, navi, radio, ranger, sound, stereo, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
