06-16-2008, 08:49 PM
A schematic would be helpful, but might not be necessary. Pull the switch panel and start doing some voltage checks. Are the inputs present?
No: check fuses and relays
Yes: move on to the output side of the switch
Is the output side present?
No: replace switch
Yes move on to the door lock actuator solenoid
Is voltage present at the solenoid when switch is pressed?
No: check the wiring harness for an open or a faulty connector
Yes replace the solenoid
I would backprobe the test points
