Quote:
Originally Posted by expy37at
This is interesting.
For a long time reading about the blend door I thought I would cut into the housing, glad to see that soemone has made a kit to simplify the work.
Question, how do you remove the center console in an additional 30 minutes?
Is the question how to remove the console or how to do it in 30min?
Ford made changes in the interior layout across the different years and different models, so this is a generic process that you can modify to fit your car.
Block the wheels and put the car in neutral. This puts the shift lever in a straight up position and makes it easy to lift the console up.
Remove the plastic panels on the sides that go under the dash.
Remove the four heavy bolts that go into the sides of the console. You will have to move the seats forward and backwards to get to the bolts easily.
Remove the trim around the console shift. It will pry out. You should be able to do this without removing the shift knob.
Remove the bolts holding the console under the shift trim and inside the console storage compartment.
Lift straight up and out.
Of course, it won't be this easy and you will have to hustle to do it in 30min, but just consider it an Olympic event and go for the gold!
cgallen
