Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-16-2008, 02:55 PM
OLDEAGLE is starting off with a positive reputation.
2003 F150 Front Bearings
This is my first post here so if I seem a little nervous, I am.
I am looking to replace the front drivers side wheel bearing hub on my 2003 F150 supercab 4X4 and I must admit I am a little apprehensive about it.
I have heard that the old hub can be near to impossible to get off, is this true and if so any tips on how to do it.
Also other that a new hub assembly do I need to replace any other items while I am in there. ie: seals or bushings?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-16-2008, 05:39 PM
KingRanchMan02's Avatar
KY KR lover
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Welcome to FTE OLDEAGLE! Read the "Read this first" thread at the top of this forum. there is a very good thread with pictures on how to do this job there. it is at the very bottom of Racerguys initial post titled How to replace the ball joints on your 97-03 F-150 4X4
Good luck!
__________________
John
aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege
5.4L 3.55 LS, 4x2
Diablosport Predator Programmer, K&N filter.
`08 Sable Premier
Merlot Metallic, Black leather
3.5L Duratec, 6 speed automatic
  #3 (permalink)
Old 06-22-2008, 08:08 PM
fordguy23 is starting off with a positive reputation.
I changed my drivers side hub assembly, and getting ready to do passenger side. I had no problems changing mine out on the drivers side. I sprayed all my nuts and bolts with pb blast, and they all came right loose. Good luck!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
