Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-16-2008, 02:16 PM
ford fisherman is starting off with a positive reputation.
Happy finds while diagnosing starter problem om my 92
My 92xlt truck wouldn't start after driving, shut off motor, no start. Happened to my wife and then it happened to me on Friday while at the Auto parts store. I wait about 5 minutes open/close hood and it fires right up. While I had it jacked up I changed the oil and started inspecting the undercarriage. Found the starter to be a loose wire. I was also very happy to find a semi-new starter, a new 5spd. Ford factory transmission, new 02 sensors, new exhuast and come to find out I have a fairly new radiator, water pump and fan. I am a happy camper . I have added a headache rack all I really need to do is replace my leaking freon hoses, accumilator and retrofit r134a and I will really be cool with my ride.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-16-2008, 04:38 PM
Pablo-UA is starting off with a positive reputation.
I changed starter. Cranked cold engine only. Did nit start hot engine. I learned that when starter was hot (manyfold is close) it did not crank engine becouse armature isolation was bad, and when it was hot it was soft and moved under load armature shorted to ground.
Later I changed armature in this starter and now it works too. I have spare one now.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
