Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-16-2008, 12:54 PM
kevbo240zz is starting off with a positive reputation.
Question 99 E-150 hard start
I was helping my friend work on his 99 E-150 4.2L v6 with 105,000 miles. he turned the key one day and it only clicked, so he put a new battery in it, then the same thing it only clicked. I came out and put a starter in, it turned over slowly and stopped. I pulled the plugs, they were original and bad! i decided to change the oil too, when i pulled the drain plug, about a quart of water came out first, then the oil. I refilled it with new oil and filter, cranked it a few times with the sparkplugs out and it turned over fine. then i put in the new plugs and wires, it turned over attemped to start, and when i tried again it turn over slowly once and stopped. I would assume the coolant maybe be original as well. any ideas?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-16-2008, 04:19 PM
BrianA's Avatar
BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.
You can do a search here, many threads over the years, but I can pretty much bet you have a leaking lower intake manifold gasket and possibly a leaking timing chain cover gasket.
I strongly suggest you do not try to start the engine again until you get the problem checked and corrected.
Further attempts can result in severe engine damage.
Here is some more info:
99-20-7***COOLING SYSTEM - 3.8L - UNDETERMINED LOSS OF COOLANT***COOLING SYSTEM - 4.2L - UNDETERMINED LOSS OF COOLANT***ENGINE - 3.8L - ENGINE OIL CONTAMINATED WITH COOLANT***ENGINE - 4.2L - ENGINE OIL CONTAMINATED WITH COOLANT
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
Alabama Chapter Leader
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
