Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2004 - 2008 F150
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-16-2008, 12:43 PM
drewk86 is starting off with a positive reputation.
Show me your CUSTOM EXHAUST!!!
I am looking into putting together a custom exhaust for my 06 regular cab with the 5.4 engine. I need some ideas of what kind of system I can make. If you can please show me your custom exhaust and what parts you used to produce it. Thanks!!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-16-2008, 03:19 PM
Anyone have a system like this...
My True Dual Exhaust (With Pics) - F150online Forums
this is what I would like to have...
  #3 (permalink)
Old 06-16-2008, 04:25 PM
tylus's Avatar
tylus is starting off with a positive reputation.
that guy went way overboard.
the factory pipes come to together in a "y" shape just past the t-case on the passenger side. he redirected the drivers bank for some reason...and I can't figure out why?
anyways, get 2 bullet style mufflers (Gibson, Magnaflow) or 1 dual inlet, dual outlet muffler (Flowmaster, Magnaflow). It's a peice of cake for a exhaust shop to fab it all up. They just have to cut the "Y" out and there is a butt-ton of room for everything else. I recommend re-using as much of the OEM pipe as possible to save $$$.
you'll also need a good "h" or "x" pipe. this allows the exhaust pressure to balance between the engine banks...and it also creates a scavenging effect. You can get the mufflers and x,h pipe on the Internet for <$150 easily...and maybe $100-150 for the install/welding
I personally recommend Magnaflow stuff. I have Flowmaster and Magnaflow right now...and the Magnaflow is my favorite hands down. Flows are just too damn loud
__________________
  #4 (permalink)
Old 06-21-2008, 12:06 PM
F250FarmBoy's Avatar
F250FarmBoy is starting off with a positive reputation.
I just took off the muffler/tailpipe and put a glasspack in its place and welded a tab on the muffler and bolted it to the stock mounting hole.
I'll get pics if I can and I'll tell you if there is any change in mileage.
__________________
1985 F-350 6.9L -- dually -- ZF SF-42 -- 4.10 -- Flatbed
Dual ram intake/bucket seats/5" stack/manual GPs
  #5 (permalink)
Old 06-22-2008, 04:42 PM
mrpositraction's Avatar
mrpositraction is gaining momentum as a positive member of FTE.
Here is my 2007 Roushcharged F150 running 9psi. The exhaust is a 2.5" true dual mandarel bent exhaust exiting in front of the passenger side tire. The muffler I am using is a 21" Magnaflow muffler wh/ has an x-pipe built in. The tips are 2 Gibson tips.
Slideshow of pictures
3 video clips ranging from inside roll, out side flyby to an inside dig.
Enjoy!
__________________
2007 Roushcharged FX4 RC Flareside (9psi)
Magnaflow True Dual Exhaust
305/60 18 Dick Cepek F-C II
  #6 (permalink)
Old 06-22-2008, 07:09 PM
GerRod is starting off with a positive reputation.
Nice system mrpositraction. I'm Roush charged as well and I'm going to do something similiar. I'm going with Magnaflow X pipe 10791 and the 22" DIDO muffler 14568. The pipes will exit just before the passenger rear tire with 2 1/2-3 1/2 Ractive slanted tips.
  #7 (permalink)
Old 06-23-2008, 07:52 AM
Quote:
I think that is the same muffler I got. You may want to check, as the muffler I have has an x-pipe built into the muffler.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
