dump bed kits
Old 06-16-2008, 07:20 AM
C350CREW's Avatar
C350CREW
C350CREW is offline
dump bed kits
anybody installed or know someone that has installed one of those dump bed kits for the factory beds? ive been looking but some look cheap and the others are way to expensive. what kind of kit, how easy to install, how well does it work??
Old 06-16-2008, 03:28 PM
ReAX's Avatar
ReAX
ReAX is offline
I've looked into it, but never did one.
The bed needs to be braced with it's own frame, most likely the kit will lift the bed up some since you will have some heavy tubing and bumpers separating the bed from the frame. Then you have the expensive parts, the cylinder should be pretty big and powered by a high pressure pump. The pump is probably the price difference, and depending if you have to have braided SS lines the kit should cost a pretty penny.
Old 06-16-2008, 05:46 PM
brownfoot's Avatar
brownfoot
brownfoot is offline
Pierce kit is reasonable (less than $1000) and easy to install, one day or less
has a 12v pump tank assembly
the bed still is in the original location, sitting on the frame, just follow their instructions
pics in my gallery on '76 highboy
Old 06-16-2008, 07:29 PM
megawatt00's Avatar
megawatt00
megawatt00 is offline
I had a 98 F250 that I put one on. I got it from Northern Tool. Not a bad setup. The bed sat at it's normal height.
Old 06-17-2008, 02:19 PM
C350CREW's Avatar
C350CREW
C350CREW is offline
did either of you guys have to mod the bed or add extra support? how much will they dump? are you happy with the brand you have?
Old 10-02-2008, 12:55 PM
Jonas1022's Avatar
Jonas1022
Jonas1022 is offline
Thumbs up
I think this is the kit my brother had installed on his 79 Lariat F-150. It appears to be an old style Chevy starter motor for the pump, and some angle iron was supplied to reinforce the bed. Works fine, lasts a long time...!
Old 10-10-2008, 07:10 PM
tmbrhg's Avatar
tmbrhg
tmbrhg is offline
I bought a venco kit came with everything including switch. its a 6000 lb capacity and is well built last year it was 1850 shipped to my door
Old 10-13-2008, 11:38 PM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
I think I would look at a dump insert. It would be more sturdy than any twisting of a standard pickup box. The only downside is they are plenty spendy at close to $3,000 when I last priced one.
Old 10-14-2008, 10:03 AM
Jonas1022's Avatar
Jonas1022
On the surface it's a good idea. But the reality is you need a plenty heavy truck chassis to carry the wieght of the bed and the payload. The dump feature reinforces the factory bed, so no twisting of any significance occurs. Of course anyone that isn't thinking about what they are doing can twist any of them. My brothers truck has had the dump feature since the truck was new in 79. By using it with caution, the truck chassis can handle it well, and the bed is larger than what it can carry wieght wise. If your not thinking though, I imagine it could be overloaded quicker than you would imagine. Insert boxes are heavy and they are in the way always. So, go for the factory bed dump kit.
Old 10-14-2008, 10:56 AM
tmbrhg's Avatar
tmbrhg
tmbrhg is offline
a local landscaper has the dump insert. he does not like it because it will only dump about 2000 pounds. ok for bark but anything heavy and it wont lift it.
Old 10-14-2008, 10:23 PM
1979 Ford's Avatar
1979 Ford
That is exactly it. I think at a minimum I would be using a host on nothing smaller than a 1 ton. But in my case it would hauling landscape materials.
Old 10-15-2008, 05:23 AM
brownfoot's Avatar
brownfoot
I have had no trouble with mine
In think the hoist is plenty strong, but the bed needs some help to stiffen
did dump 2500 lbs. of rock, but loaded nearer the back of the bed
I agree, you can put more in the bed than the truck should haul, just keep the weight in spec and you will be ok
f100today
13
12-08-2016 01:57 PM
madscientist
1999 to 2016 Super Duty
07-06-2015 05:52 PM
boxcar1974
01-30-2005 10:12 PM
jw1308
11-19-2002 10:40 PM
mramoo
1983 - 2012 Ranger & B-Series
07-28-2000 07:25 PM
Quick Reply: dump bed kits
