water temperature 230 degrees too high?
I have a 1993 E350 HD Club Wagon. It has no aftermarket performance upgrades. The engine is a 5.8l and the rear gears are 3.54.
I put in a super stant 195 degree thermostat ( I verified the thermostat opens corectly using a candy thermometer) and replaced all the hoses. I have installed a high quality mechanical water temperature gauge (that I tested with boiling water to verify it's accuracy).
When driving to the freeway on two lane roads, about 8 miles, the temperature gets to 200 and stays there. Once I get on the freeway the temperature rises to 230 and stays there. If I get off the freeway and drive 45 mph, the temperature will go down to 210.
I am concerned that 230 is too high. From searching threads here I have found a lot of differing opinions. Some say 200 degrees some say 230 is ok. Should I be concerned? Should I replace the radiator? How do I know the water pump is good?
Yeah, 230 is too high. The water temp should maintain 195~200 F. I am wondering where you are taking the temperature reading though. If the sensor is located in a spot where an air pocket can form, your reading will be inaccrate.
Have you verified the system is full?
The radiator could be partically stopped up or the fins bent/plugged.
The other think that can cause this exact symptom is if the water pump impeller is being eaten away by corrosion.
I have the gauge sensor in the original location, on the intake manifold, next to the distributor.
I am not sure about a pocket of air... don't know how to verify that.
I have double checked and the radiator is full.
The fins on the radiator look okay from what I can see.
I cannot verify the condition of the water pump impeller.
From what I can see inside the radiator it looks like there is rust and junk in the tubes that I can see.
I did order a new radiator today. I am keeping my fingers crossed that this will be my fix.
rikfish thanks for the tip. How do you go about checking the cat? Do you pull it off?
coolfeet
10-17-2015 10:58 PM
johaner78
09-12-2011 08:31 PM
