Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-15-2008, 08:24 PM
pagliai69 is starting off with a positive reputation.
64 f100 rear brake questions
I have a 64 f100. Almost road ready, but i want to get the e-brake to function somewhat. I am needing/wanting to remove the rear hub and I read somewhere that I have to pull the axle out to do so? It's been a few years since I worked on one, but I don't remember pulling the axle to do a brake job. Usually just used a bfh to get it off. If someone know for sure, or know a easier way it sure would be apprieciated.
Thanks in advance
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-15-2008, 10:48 PM
Oldnslofly is starting off with a positive reputation.
What rearend you have under your truck?
  #3 (permalink)
Old 06-15-2008, 11:14 PM
I'm not sure. How do I tell?
  #4 (permalink)
Old 06-16-2008, 12:00 AM
camperspecial65 is gaining momentum as a positive member of FTE.
look at the doortag..post the axle code...also, number of lugs and look under the middle looking rearward...see if the carrier is bolted to the housing or not.
- cs65
  #5 (permalink)
Old 06-16-2008, 12:31 PM
114 B F100 C81 A 12
5000 135 3800 63
  #6 (permalink)
Old 06-16-2008, 12:52 PM
bigperm2 is starting off with a positive reputation.
you have to pull the axle if its a full floater Dana 60 (8 lug axle). Since you have a F100, I would assume you have the 5 lug, semi-float 9" (or dana 60) You should be able to pull the drum off without removing the axle.
__________________
'73 F-100, 2wd 428 edelbrock heads/intake STOLEN!
'68 bronco, uncut w/ 3.5" lift and 33s megasquirt EFI
'73 F-250, '78 4x4 frame w/ 400, NP435, NP205
'66 F-100, SWB 2wd, w/352, NP435
  #7 (permalink)
Old 06-16-2008, 02:29 PM
airharley's Avatar
airharley is gaining momentum as a positive member of FTE.
9 inch if I remember the axle code correctly. The axles do not have to come out to pull the drums off. It's a matter of loosening the shoe adjusters and breaking the rust around the lug and center hole. Once that is done they pull off without too much fuss.
A visual clue to the 8 or 9 inch is the only hardware on the center of the axle will be on the front side where the driveshaft connects to the pinnion. There will be nuts all the way around the outer "chunk" holding it in the housing.
__________________
Mark J. Covill
"I'm not handicapped, I'm handicapable!"
'64 F-100 Shortbed 460/C-6
'03 F150 Shortbed 5.4L/4R70W/3.55 LS
Author of the disc brake article for 57-64 F-100's
  #8 (permalink)
Old 06-16-2008, 06:07 PM
matt2491's Avatar
matt2491 is new and has a neutral reputation at this point.
Quote:
Exactly what he said. When I first did my brakes, one of the drums was SO stuck on the hub that I actually took a huge iron rod, pushed it under the truck so that one end of it stuck out on the other side of the truck, and the other end set against the backside lip of the drum. Then my Dad took the BFH and swung at it real good. After a few swings, it still wouldn't budge. I ended up using heat and going crazy with the BFH. Lucky I didn't distort and break anything, but it was a major pain in the ass. Naturally, the other drum popped off with a problem.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
