1997 F150 4WD Vacuum Solenoid Problem - Ford Truck Enthusiasts Forums
Old 06-15-2008, 02:29 PM
pjtessy pjtessy is offline
pjtessy is starting off with a positive reputation.
I have 97 4x4 f-150 V6 4.2 litre that in 2wd tries to go into 4wd causing a grinding then a thump. When I put the truck into 4wd there is no grinding or thumping.
I believe one of the vacuum solenoids could be bad. Just was wondering which one would cause it to want to go into 4wd while in 2wd.
The left most solenoid looking under the hood is the 4wd and the other with the pink vacuum is the 2wd.
I have no vacuum from the solenoids but from the lines going into them.
Old 06-15-2008, 02:39 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
There should always be vacuum on the colored line leading from one or the other solenoid. The vacuum keeps it "drawn" into whichever mode is selected. Your diagnosis is correct and the 2WD solenoid should be bad. You know of course that these solenoids only affect the front axle being engaged or disengaged and has nothing to do with it actually being in 2 or 4 wheel drive.
Old 06-15-2008, 02:54 PM
Thanks for your reply and info!
Old 06-15-2008, 03:10 PM
ncranchero's Avatar
Welcome to FTE , we're always happy to help!
I had a lot of problems with my axle vacuum system when I first got my '98. Took a while but did get it straightened out. My guess is that the 2WD solenoid goes bad because that's the one activated most all of the time. I picked one up at the salvage yard off of an Expedition. If you go that route grab the lines too since they sometimes crack/break.
Old 06-15-2008, 03:45 PM
Will do!
Thanx so much.
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 01:59 PM
2010 f250 super duty vacuum solenoid not getting electricity Chris82458 1999 to 2016 Super Duty 4 12-16-2015 02:25 PM
IWE actuaters strat875 Modular V8 (4.6L, 5.4L) 0 11-28-2015 11:12 PM
Thump thump thump from the rear when turning stickyrice 1999 to 2016 Super Duty 3 05-13-2012 12:37 PM
04 f150 IWE solenoid troubleshooting klmarton 2004 - 2008 F150 2 06-18-2007 10:42 AM
Tags
42, 4wd, 97, activates, f150, solenoid, solenoids, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
