Spark plug socket stuck
03-17-2017, 12:04 PM
i just purchased an '01 expedition with the 5.4. I was told #5 spark plug blew out. Upon examination, it appears to be #6, second from the front driver side. Anyway, as I was looking, it just didn't look right. There was a spark plug socket stuck in the well, with the plug still in place. Any suggestions on how to get the socket out? I can get an extension on it and it will turn, but it's tight. But I can't pull the socket out.
03-17-2017, 12:12 PM
Can you get a tool with a bent tip to get in through the 3/8" opening, hook the inside of the socket, and use that to pull it out?
03-17-2017, 12:55 PM
03-17-2017, 02:12 PM
Also for changing plugs in my truck I bought a gear wrench socket that has a permanently attached extension. Kept loosing the socket in the hole once the plug was tight.
John
03-17-2017, 03:24 PM
It sounds like that, beside the socket being stuck in there, the thing will turn but the plug won't back out suggesting a failed insert or helicoil or a set of stripped threads.
This is going to be messy....
03-17-2017, 06:11 PM
I've been trying to get it out with a pick. Not having much luck. Thinking about starting the truck to see if it will blow out again.
03-17-2017, 08:00 PM
Get an extension in it, then turn it rapidly with an air tool or drill as you pull it upward. The trick here to try and break the friction as you're lifting.
03-29-2017, 10:26 PM
Put some gel super glue on the end of the extension. Then insert it into the socket and wait 10 minutes. Shouldn't have any issue pulling it out. Dip it in acetone to dissolve the superglue. I super glue the extension and spark plug socket together every time I install spark plugs in a triton.
04-02-2017, 02:14 AM
get a locking extension like Craftsman sells, spray some solvent like WD40 then use the extension as a handle to pull on.
just an idea
04-05-2017, 10:22 PM
Finally got it out. Mystery oil and a pick. Thanks for all the input.
ugltrk
Aerostar
13
01-10-2018 05:03 PM
dannymo
1997 - 2003 F150
21
02-18-2008 09:27 PM
BigDASH
1997-2006 Expedition & Navigator
09-06-2006 11:54 AM
Mr.Ford 351W
Garage & Workshop
18
09-15-2005 04:01 PM
Keymaster
1997 - 2003 F150
03-06-2005 12:27 AM
