I have an '86 f250 4x4 6.9l with a c-6 ... The problem is that in "D" it revs to around 2,500 before shifting and then it clunks ... If I start off in "2" it shifts from first to second just fine ... Then I can put it in "D" and third comes in fine too ... Fluid is clean and right on the mark ... Reverse is ok too ...
__________________
Current:
1986 Ford F250 XL Exploder-4x4-6.9 IDI-C6
.. body by Rusty Crunchy
1986 Jeep Cherokee Pioneer Limited-2.8L P.O.S.
Past:
1965 Chevy "Assembled" 1/2 ton
1964 Chevy 3/4 ton
1964 GMC 1/2 ton
1967 Buick Special, 310 Wildcat, 2-speed slushbox
1967 Fairlane GT 500, 428 Cobra, twin turbo, NOX
My truck is around the same as yours except i got the 460 and my tranny shifts like that all the time but its also has a shift kit...but i know some other guys with stock c-6 trannys that shift exactly like that so im wondering if its normal
Set me straight here please.
You say the transmission shifts when placed in "2" position?
86 C6's have a select shift valve body.
That means when the lever is placed in 2 that's all there is, second gear, there ain't no mo.
D position has 3 speeds.
__________________
Transmission builder since 1964.
2002 Ranger.
3.0 engine.
So as I understand you:
---If I put it in "1" that is first only as with almost any other tranny---
---When I put in "2" then I have no first but it starts out in second and only uses second like a stick ---
---When I put it in "D" then it starts in first, shifts to second then to third ...
Are these assumptions correct?
__________________
Current:
Past:
1964 Chevy 3/4 ton
1964 GMC 1/2 ton
ok ... But I am still concerned that my diesel seems to want to wind up to around 2,500 rpm before shifting ... Looks like I might have to take the tranny apart and rebuild it ...
__________________
Current:
Past:
1964 Chevy 3/4 ton
1964 GMC 1/2 ton
With a shifting problem check the vacumn system. The diesels have a vacumn pump on the fender and a vacumn regulator on the throttle lever at the injection pump. You need the right amount of vacumn at the transmission vacumn modulator for proper upshifts.
Disconnect battery ground cable and remove shield, if equipped.
Loosen vacuum pump adjustment bolt and the pivot bolt, then slide pump downward and remove drive belt from pulley. If vacuum pump drive belt is to be replaced, alternator drive belt must be removed.
Remove hose clamp and disconnect pump from hose on manifold vacuum outlet fitting.
Remove pivot and adjustment bolts and the bolts retaining the pump to the adjustment plate.
Remove vacuum pump and adjustment plate. Vacuum pump is serviced as a unit. Do not attempt to disassemble.
INSTALLATION
Install pump to adjustment plate attaching bolts, torquing bolts to 15---20 ft. lbs. on 2.2 liter engine, 11---18 ft. lbs. on 6.9 liter engine, or 10---20 ft. lbs. on 2.3 liter engine.
Position pump and plate on vacuum pump bracket and loosely install pivot and adjustment bolts.
Connect hose from manifold vacuum outlet fitting to pump and install hose clamp.
Place vacuum pump drive belt on pulley and adjust belt tension to specifications, torquing pivot and adjustment bolts to 15---20 ft. lbs. on 2.2 liter engine, 11---18 ft. lbs. on 6.9 liter engine, or 10---20 ft. lbs. on 2.3 liter engine. Alternator belt tension must be adjusted before vacuum pump belt tension is adjusted.
Install shield, if equipped, and connect battery ground cable.
Start engine and check operation of brake system. Brake light will remain on until vacuum builds up to normal level.
__________________
2002 Ranger.
3.0 engine.
I infer by Stuart1's post that the vacuum pump effects both the tranny and brake operation ... Brakes work fine ... No fading or pulling ... Nice even stopping without having to floor the pedal ...
__________________
Current:
Past:
1964 Chevy 3/4 ton
1964 GMC 1/2 ton
