Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-15-2008, 12:04 AM
willys_gasser is starting off with a positive reputation.
351w motor mount ?'S
I am putting a 351W in my 65 f100, I already have 78 302 engine stands. What engine mounts do I need? I looked up (on the napa website) a couple of different cars and trucks with a 302 and a 351W and they all showed different part numbers.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-15-2008, 06:12 AM
jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.
Willy There were no Ws installed in trucks until the 80s, so there will not be any reference to parts that you can use. In 80 everything changed.
I could stand corrected, but imagine late 70s 302 mounts would work.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #3 (permalink)
Old 06-15-2008, 06:26 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
Quote:
Originally Posted by jowilker View Post
Willy There were no Ws installed in trucks until the 80s, so there will not be any reference to parts that you can use. In 80 everything changed. I could stand corrected, but imagine late 70s 302 mounts would work. John
John, the 1969/79 302 engine stands are the same part numbers as the 1977/79 351M/400 2WD engine stands.
Someone here has posted several times that the 302 rubber mounts will work on 351W's...but there's no parts catalog ref that sez that.
No 351W's were installed in F150/350's (or Bronco's) till 1981.
1980/83 F100's didn't use the 351W engine, the largest engine available on these F100's was the 302.
__________________
Bill / Retired Ford Partsman ~ 1962/1997
Part Number Research available for the following: Trucks: 1928/2002 / Cars: 1928/2000
  #4 (permalink)
Old 06-15-2008, 02:37 PM
Thanks Bill, but before I get confuzed, I believe Willy said that he had perches, that we know will fit, right??
I thought he was asking about the rubber engine side mount, no??
Help me out where did I go wrong??
John
__________________
  #5 (permalink)
Old 06-15-2008, 02:47 PM
Ford Parts Guru
But what perches and from what vehicle? It depends on what they're from. Econoline, Bronco or anything from 1980 and later will not work.
I thought he was asking about the rubber engine side mount, no?? Correctamundo.
Help me out where did I go wrong?? You didn't.
John
What perches he has, and what they're from, I dunno...he didn't say.
Because he didn't say, I was merely pointing out that the perches (stands, brackets, supports whatever ppl wanna call them) are the same for F100 302's from 1969/79, F150's from 1975/79, and are the same as 1977/79 F100/350 2WD 351M/400's.
As you said, there's no parts catalog info. Some ppl here have said 302 rubber mounts will work on a 351W. Personally, I dunno.
__________________
  #6 (permalink)
Old 06-15-2008, 05:48 PM
yes, I have the metal engine stands from a 78 f150 with a 302. I am needing to know what mounts "they bolt to the block " I need.
  #7 (permalink)
Old 06-15-2008, 09:45 PM
Oldnslofly is starting off with a positive reputation.
Motor mounts
Hey man log on to LMC truck parts or what ever its called. They have motor mounts listed in their catalogs for what you are looking for.
I would create a link for you if I was computer savy.
Type in LMC truck parts into your browsers search function and you should get what you need.
If you can't find it post back and I will try and pull out my old catalog and post part number and phone number for you
  #8 (permalink)
Old 06-16-2008, 06:29 AM
Ra_ Ra_ is offline
Ra_ is starting off with a positive reputation.
The 302 and 351W mounts are the same so all you need to do is order a set of '78 302 mounts. The 351W i have has followed me through a couple different cars and each time i've used 302 mounts.
  #9 (permalink)
Old 06-16-2008, 12:25 PM
thanks, Ra that is what i was looking for.
  #10 (permalink)
Old 06-17-2008, 05:19 AM
Zackly what I thought, but because I hadn't done it, I couldn't say for sure.
John
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
