Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-14-2008, 11:43 PM
teds74ford teds74ford is offline
teds74ford is gaining momentum as a positive member of FTE. teds74ford is gaining momentum as a positive member of FTE.
78-79 F150-style steering w/chevys tech thread
Disclaimer: this isn't meant to be a step by step, but merely how I did it and what snags I ran into.
I have never liked my old steering. It wandered slightly on road, and was quite labor intensive offroad. There is no slop, but just a bad design, exaggerated by the lift.
I decided to do a 78-79 F150 style steering. After looking into stock parts, I started to look at the Chevy 1 ton TRE option. It ended up being only slightly more expensive than the stock parts would have been. The advantages are that I get heavier duty parts, and a little better tie rod ground clearance.
The parts I used:
stock 78-79 F150 pitman arm
Chevy ES2026R, ES 2027L, ES2233L, ES2234R
Shakerbilt heavy duty rock rods
Chevy tapered reamer from "xcut"
The shakerbilt specs I gave Tim (at shakerbilt) were a 55 1/8" tie rod, and a 41 5/8" drag link. This ended up being cheaper than bare tubing and inserts by a few bucks.
On to the pics:
Old Tie rod clearance- about 14"
I had to grind my old pitman to get the puller on it.
I ended up taking out the steering box bolts to get the arm to clear the track bar bolt.
The Xcut reamer. For what it is worth, the pitman arm and TRE were MUCH harder to ream than the knuckles.
I flipped my tie rod over the knuckle, yielding about 3" more clearance.
I ran the drag link up thru the bottom of the pitman.
Here is ES2027L inserted in ES2233L.
The completed steering. I ended up reversing the track bar bolt to clear the tie rod ( the castle nut is toward the rear of the truck)
I tried to match my drag link and track bar angles by using the tie rod over knuckle, but it isn't exactly perfect. At least the goal of better clearance was achieved. Hopefully this will help someone else. I never could find out how long the tie rod and drag link needed to be, so hopefully this will make it easier for others.
There it is. Fire away.
  #2 (permalink)
Old 06-15-2008, 12:26 AM
Tre-E_Ford's Avatar
Tre-E_Ford Tre-E_Ford is offline
Tre-E_Ford has a good reputation on FTE. Tre-E_Ford has a good reputation on FTE.
good work, looks good to me. How does it perform?
__________________
Alex
TRE E!
77.5 F250 A.K.A. Maggie - waiting for tube
Quote:
Originally Posted by Jesus View Post
XI. Thou shalt not edit others signatures.
  #3 (permalink)
Old 06-15-2008, 12:46 AM
Just finished last night. Today was home improvement day. Hopefully will know tomorrow.
  #4 (permalink)
Old 06-15-2008, 01:10 AM
straightsix4x4's Avatar
straightsix4x4 straightsix4x4 is offline
straightsix4x4 is starting off with a positive reputation.
I like, sounds out of my price range for now though. you did gain a decent amount of clearence on that
  #5 (permalink)
Old 06-15-2008, 02:35 AM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE.
Now you have some steering there. You should be very happy with that style over the "y" steering that you had. Should be rock solid now.
Great Job man!
  #6 (permalink)
Old 06-15-2008, 08:08 AM
STGFordCrazy04's Avatar
STGFordCrazy04 STGFordCrazy04 is offline
STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold
X2
great job man.
Fredrian,
tech thread?
__________________
Kris
Please do not PM me. My email is STGCountryboy312 at AOL dot COM
Quote:
Originally Posted by thorseshoeing
Yes you are the anti christ...
  #7 (permalink)
Old 06-15-2008, 08:54 AM
Quote:
Originally Posted by STGFordCrazy04 View Post
X2
Fredrian,
tech thread?
This is what I was hoping. Maybe this will help out others in the future.
  #8 (permalink)
Old 06-15-2008, 08:58 AM
Quote:
While it wasn't cheap, it wasn't THAT expensive compared to stock stuff. I got lucky. Here's a rough breakdown of cost:
Pitman: $10
Chevy TREs: $70
Shakerbilt tube: $170
At a grand total of $250 plus the reamer, I am not much over LMC's price for 78-79 stuff. I got 3 of my TREs off craigslist for $40 and had to buy one new.
  #9 (permalink)
Old 06-15-2008, 09:51 AM
you couldve come out even cheaper if you bought the DOM yourself.
__________________
Kris
  #10 (permalink)
Old 06-15-2008, 10:08 AM
I priced it from several places online, and after buying the inserts at $10 a piece, it didn't come out cheaper. Maybe it would have been cheaper if I bought it locally, but it wasn't cheaper thru any of the online places.
  #11 (permalink)
Old 06-15-2008, 10:29 AM
dragogt's Avatar
dragogt dragogt is offline
dragogt has a very good reputation on FTE. dragogt has a very good reputation on FTE. dragogt has a very good reputation on FTE. dragogt has a very good reputation on FTE.
Good job rep to ya.
__________________
92 Isuzu Rodeo 5sp 4x4
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
Aaron -STG's - Pirate Investigator
Quote:
Originally Posted by captain p4 View Post
If you can't tell if you have a body lift or not maybe you shouldn't be giving people advice in the offroad forum????
  #12 (permalink)
Old 06-15-2008, 10:33 AM
Quote:
6 months ago when I did mine I payed $202 for 22' of 1.5" .250 dom and $11 each for tube inserts. I guess it all depends on where you go. Metal has also had a few drastic increases since then.
__________________
Kris
  #13 (permalink)
Old 06-15-2008, 10:38 AM
Tre-E_Ford's Avatar
either way, good work and much appreciated for the info. what size reamer do you need?
__________________
Alex
TRE E!
  #14 (permalink)
Old 06-15-2008, 02:24 PM
I wish I could have gotten the tube that cheap. Regardless of which way you do it, it is much better than the stock stuff, and about the same price. That's the main reason I went with it.
As far as the reamer, I believe it is a 7 degree taper. The reamer is pretty big, but you only use the first inch or so.
  #15 (permalink)
Old 06-15-2008, 02:35 PM
standard taper for Chebby TREs is 1.5" per foot or 8*.
__________________
Kris
Tags
es2233 , es2234 , rod , tie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
