Rear end axel for 1999 E350 same as 2002 F350? - Ford Truck Enthusiasts Forums
Old 06-14-2008, 07:14 PM
slk133 slk133 is offline
slk133 is starting off with a positive reputation.
Hi ,
I was wondering if anyone can help me. I need to know if a 2002
Ford F350 rear end axel (that slides in from back) is the same as a 1999 E350 Super Duty (4:10) rear end axel.
Old 06-14-2008, 07:40 PM
BadDogPSD's Avatar
BadDogPSD BadDogPSD is offline
BadDogPSD is gaining momentum as a positive member of FTE.BadDogPSD is gaining momentum as a positive member of FTE.
Don't think so...
Pretty sure the van rear axles are Dana's vs. Ford Sterling in the SD's.
Old 06-14-2008, 08:11 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Check for a metal tag on the diff. The manual lists Dana 60 & 80, Ford (Sterling) 8.8 & 9.75, as well as a Dana S135.
Old 06-14-2008, 10:21 PM
rebelchevy02's Avatar
rebelchevy02 rebelchevy02 is offline
rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.rebelchevy02 has a very good reputation on FTE.
Also, van axles are generally wider then truck axles. I dont know in this application if thats 100% true or not, but Im pretty certain it is. Can I ask whats wrong with yours?
Old 06-15-2008, 07:27 AM
Markadeck's Avatar
Markadeck Markadeck is offline
Gone, but not forgotten
Markadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant future
Quote:
It's snapped (drivers side) and he's stuck on side of road out in the middle of nowhere. There is another thread going presently on the same subject.
Old 06-15-2008, 07:34 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
That's prolly the fellow that P/M'd me and asked what axle would fit.
The problem I'm having is, he didn't say what vehicle he had, and only gave me some numbers that made no sense.
I P/M'd him back, but he never responded.
What does he have, a 1999 Econoline E350 or the 2002 F350?
If I knew where he was broken down, I could search thru the Ford dealers parts inventory locator system and maybe find him an axle close by.
Old 06-15-2008, 07:37 AM
Markadeck's Avatar
What does he have, a 1999 Econoline or the 2002 F350?
I think I read E350 in the other thread, will check in a sec.
Old 06-15-2008, 07:40 AM
Markadeck's Avatar
It is mentioned in his signature only. So that must be it. He is not making himself very clear in any of his posts.
Old 06-15-2008, 07:50 AM
The old partsmans lament...ppl fail to give any (or enough) info.
It happens at parts counters, it happens here every ^%$#* day!
You can't always go by sigs or profiles because some ppl own more than one vehicle.
Since I just cleaned out my mailbox, I have no klew who P/M'd me...is the OP the one who needs the axle? If not, what's the fellows user name?
Did he say where he's located?
Old 06-15-2008, 07:56 AM
Markadeck's Avatar
Nope, been very vague about everything. Wonder if he's on the lam? But here's a link to his other thread.
http://www.ford-trucks.com/forums/75...ease-help.html
Old 06-15-2008, 08:35 AM
Done deal thanks.
I gave him the bad news, the axle shafts are not the same, they're Econoline SD only.
Old 06-15-2008, 08:36 AM
Done deal, thanks.
Old 06-15-2008, 08:38 AM
Done deal, thanks.
I gave him the bad news, the axle shafts are not the same, they're Econoline SD only, and are right/left specific.
FTE has another case of the slows again...takes forever to load a message.
Old 06-15-2008, 11:04 AM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
I guess when I sugested he PM ND I should have also sugested he give some proper info
All I could come up with is he had a '97 and a '02 E350 and wantrd to use an axle shaft from th '97 in the '02
Old 06-15-2008, 11:49 AM
Weres he at? I have a spare set of axleshafts sitting around.... If hes close, I could donate. 814 571 4568 cell.
However, mine is a SRW sterling axle.
Dana Axel Identification ScottInTexas 1999 to 2016 Super Duty 7 06-11-2015 05:12 PM
Removing axel housing and replacing Mechanicalroofer 1999 to 2016 Super Duty 0 09-09-2014 04:17 PM
'87 Ford F150 rear swap with '98 Ford Explorer Rear end Skydive80 1987 - 1996 F150 & Larger F-Series Trucks 7 08-20-2012 02:30 PM
2000 F350 single rear Axel swap to Dually Axel Question idesign 1999 to 2016 Super Duty 10 03-18-2011 12:01 PM
2000 F350 4x4 front axel dust seal/shield vonleyser 1999 - 2003 7.3L Power Stroke Diesel 2 01-02-2011 07:16 PM
Tags
1999, 2002, 350, 60, 8145714568, 975, 99, dana, e350, end, f0tz4234a, f350, ford, oil, propane, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
