2000 ford explorer
Old 06-13-2008, 10:25 PM
MJGRAY66's Avatar
MJGRAY66
MJGRAY66 is offline
2000 ford explorer
I have a 2000 Ford Explorer ran out of gas at gas pump! Filled up and NO START! Listened for fuel pump to prime couldnt hear anything. Next day checked for fuel coming out at fuel filter nothing. So figured pump had burned up. Also had looked for cut off switch that possible got triggered couldnt find on. Changed pump and still nothing. Pump will not cycle. Checked fuses but cant find one thats bad. Any ideas why i'm not getting power to the pump?
Old 06-13-2008, 11:03 PM
jimm66's Avatar
jimm66
jimm66 is offline
I think you better move your post to the explorer section. But welcome to FTE. You will be helped there.
Old 06-14-2008, 03:02 AM
broncobran68's Avatar
broncobran68
broncobran68 is offline
You need to locate your fuel pump relay under the hood somewhere and have someone cycle the key while you feel the relay and see if its clicking. If its clicking you most likely need a pump. If not most likely a relay. How many miles do you have?
Old 06-15-2008, 12:00 AM
MJGRAY66's Avatar
MJGRAY66
MJGRAY66 is offline
about 88000 changed the pump and also the relay switch still nothing. pump wont even come on. today dropped tank again and checked everthing...pump good...so changing out fuel regulator....if that doesnt work not sure where else to check.
Old 06-15-2008, 07:47 PM
bass3006's Avatar
bass3006
bass3006 is offline
If you have not located the cut off switch, check right next to the door on the passenger side by your feet, under the the glove box. There is a fuel shut-off module thingy that is supposed to trip when the vehicle is involved in an accident. So... you should have one, my 2000 Ex has one. If you were not in an accident, I dont know why it should trip or if its the cause of your problem.
ford150ford350
1997 - 2003 F150
11-23-2012 09:44 AM
knuckleheadrider
04-20-2012 06:45 AM
storj24
Electrical Systems/Wiring
05-08-2010 08:23 PM
dffdixie
1983 - 2012 Ranger & B-Series
19
09-11-2009 11:02 AM
dustineinertson
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
02-18-2009 11:18 AM
Quick Reply: 2000 ford explorer
