97 Expy kills battery after setting for a week
Take off both battery cables and check the resistence betwwen them. Sounds like you may have a short or a small draw on your battery. Optima batteries are the best. Put the positive cable back on the battery and put an amp meter between the negative post and the negative cable mounting terminal to see how much draw there is in the connection. If you don't have an infinite resistence reading or zero amp draw sell it quick.
alright, here is a tip for you, you will not have a 0 amp draw or infinite resistance if you do what kaboom says. There is always some juice being used. (keep time on the clock, run the underhood light, keep your ecu tuned, etc.) your best bet is to do what kaboom says and test the current draw, then start pulling fuses one at a time until the draw drops significantly. I have never had this problem myself but that is what others have done.
also on a side note, get your battery tested (autozone will do it for free) if the battery is damaged, it may not hold a charge for as long as it should. This did happen to me and got to the point where it would drain out within a day.
If you're still drawing that much after that time, you have a problem. Normal draw should be around 50-100 mA max after timeout.
Steve
Just wanted to let all know that the problem is the factory radio, when I disconnect radio discharge drops to just a few ma's. After thinking about this I have had intermittent problems with the radio like forgotten memory, goes blank, won't turn on. When I removed also noticed bottom was quite warm, so next is what yo replace it with.
Woody1255
07-27-2008 05:55 AM
