rear suspension??? - Ford Truck Enthusiasts Forums
Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
rear suspension???
Old 06-13-2008, 01:32 PM
upriverjoe upriverjoe is offline
upriverjoe is starting off with a positive reputation.
rear suspension???
have a 78, f150, 351m, 4x4, 4spd, 6" lift, 38x12.50x15, 7ft bed, duel h/d after mkt. shocks on front, h/d after mkt. on rear, 3/4 ton rear end. just loaded a cord of wood, lifted my front end enough to make steering squirrelly. anyone have any idea's that might help.
thanks
Old 06-13-2008, 06:10 PM
FESTER1st's Avatar
FESTER1st FESTER1st is offline
FESTER1st is starting off with a positive reputation.
OK all kinds of missing info.
A 3/4 ton rearend in a 1/2 ton truck ????
Did you change the the 1/2 ton springs when you changed the rearend and height?
The wieght capacity of the springs must be increased in order to keep the front end down unless you loaded the very rear of the bed heaviest.
Air bags are the greatest way to increase suspension capacity but with a lift may be difficult to fit correctly.
Remember you started with a 1/2ton and trying to load it to 3/4ton capacities can have adverse effects.
Shocks are only designed to keep the existing suspension from bouncing up and down not support the load (unless coilovers are used). HD just means the abilty to keep heavier capacities stable.
Old 06-13-2008, 06:19 PM
thanks you know i didn't switch leaf springs. but i'm going to. where can i locate coil overs?
thanks again
Old 06-13-2008, 07:03 PM
FESTER1st's Avatar
URJ I noticed you posted in 2 threads so keep track of both. Coil overs are shocks that have beefy small coilsprings around them. Can be purchased at any tire center or auto supply. Go with the bags if you are going to load this truck frequently. Bags do not alter ride cushion, suspension travel and flex. Check other thread.
Old 06-13-2008, 08:24 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Honestly? The best way is to not load down a lifted truck like that-
How did you lift it 6" without changing the springs?
Old 06-14-2008, 04:05 AM
Eric C.'s Avatar
Eric C. Eric C. is offline
Eric C. is starting off with a positive reputation.
Got to agree with six. Unfortunately the only way to load a truck is to stay within capaities. Air bags are only good for leveling. They will not increase capacity of the vehicle itself even with the heavier axle. I wouldn't use coil over shocks at all. I've seen to many shock mounts fail and this wasn't carrying added weight just the normal loading of the shocks.
Old 06-14-2008, 12:29 PM
ok, i think i'll just install 3/4 ton leaf springs. thanks again
1997 after mkt. tack problem 39pu 1997 - 2003 F150 7 03-25-2014 10:28 AM
recommended after-mkt. body parts white-horse 1994.5 - 1997 7.3L Power Stroke Diesel 16 11-28-2012 05:03 PM
New ride Johnny Langton Crossovers 0 11-26-2011 05:46 PM
H.D Front End? 302F250 Brakes, Steering, Suspension, Tires, & Wheels 1 03-25-2008 10:00 AM
Cup Holders ercaraker 1987 - 1996 F150 & Larger F-Series Trucks 13 02-08-2006 09:15 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
