Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > British Columbia
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
British Columbia British Columbia
Join Chapter, Leader: Zip
  #1 (permalink)
Old 06-13-2008, 01:41 AM
rob188's Avatar
rob188 rob188 is offline
Garage is empty, add now
rob188 is starting off with a positive reputation.
vibration
in my 07 f150 with the 4.6 i seem to get a vibration @ Idle, my rpms are right above 500 but i think thats normal? anyone had this issue?
__________________
current: 2008 Escape XLT AWD 3.0L v6
prev: 2007 F150 XLT 4.6L v8 3.73 limited slip
  #2 (permalink)
Old 06-16-2008, 09:09 PM
Zip's Avatar
Zip Zip is offline
BC Chapter LDR
1979 Ford Bronco
My Garage
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
My first thought would be a miss but I'm probably wrong. I think my 5.4 had an idle somewhere in the 600 range.
__________________
Chris,#12 BS'er/Official Slackmaster #7/AVIDEST WINTER HATER
BC Chapter Member/Leader
JOIN THE BC CHAPTER HERE
  #3 (permalink)
Old 06-18-2008, 02:42 PM
rob188's Avatar
thats what sdome of the guys at the shop here are saying but they also say there could be dirt in the throttle body or too much oil.
__________________
  #4 (permalink)
Old 06-19-2008, 11:36 AM
Mr. Fixit Mr. Fixit is offline
Mr. Fixit is starting off with a positive reputation.
It could easily be a dirty throttle body or even just a couple of fouled spark plugs - maybe a faulty plug. Have you replaced the plugs? Have you checked that all the high tension wires are firmly in place at the plugs? Isn't she still under warranty?
__________________
Still saving lost causes...
  #5 (permalink)
Old 06-19-2008, 11:41 AM
rob188's Avatar
yeah she's still under warranty, if it wasn't yeah i'd be under that hood real quick pullin plugs n **** but i don't wanna void the warranty and tamper with it so i better do it through ford that way if it turns out to be more then just dirt i won't have to pay for parts. the truck only has 28800km on it
__________________
  #6 (permalink)
Old 06-20-2008, 06:18 PM
Canadian98f1504x4's Avatar
Canadian98f1504x4 Canadian98f1504x4 is offline
Canadian98f1504x4 is starting off with a positive reputation.
I had the same rough idle in my 98 4.6l. It turned out to be the plug hole had water in it. It was shorting out the wire so the engine was missing. Probably not your cause though as they would find it quickly at the dealership. Mine happened a few different times and I cleaned by pulling the wire and blowing out the hole with compressed air. It didn,t always through a code either. Good luck with it.
  #7 (permalink)
Old 06-20-2008, 08:31 PM
rob188's Avatar
yeah they cleaned my throttle body i've noticed a difference in acceleration but not so much in the idle, vibration is less but still there, searched the PCM for codes, none came up, next step is try some injector cleaner and maybe take an airline to the plugs
__________________
Tags
2007, f150, limited, slip, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
