56 f600 cummins conversion - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 06-13-2008, 02:15 AM
rustyrelic's Avatar
rustyrelic rustyrelic is offline
rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.rustyrelic has a great reputation on FTE.
I started my cummins conversion, pulled the 272 and t98 4sp removed the front clip, had to remove both front and rear engine crossmembers and had to notch the front crossmember , fab. up a front mount for the cummins ( I'm using the factory ford mounts from the f700 ... three point... each side of the flywheel housing and center mount under the front of crank) the engine is now in the truck. Next is install bellhousing and plan how to make the clutch linkage. photos of current progress in gallery
Old 06-13-2008, 02:24 AM
rob188's Avatar
rob188 rob188 is offline
rob188 is starting off with a positive reputation.
nicley done lookin forward to readin about the end result!
gusso's Avatar
gusso gusso is offline
gusso is starting off with a positive reputation.
rustyrelic,
WOW!! Very innovative. Hope all goes smooth. Your going to have one unique ride
and drive with lots of pride. Good luck.
Gary
Old 06-13-2008, 02:57 AM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
Very cool!
I was going to do the same thing for the most part. I decided against it when I couldn't find a suitable engine and transmission.
What transmission are you going to use and what are you going to do for a parking brake? My plan was to use a 47RE (because of the TALL OD) but I couldn't find anyone that could tell me if I could adapt a parking brake to a 47RE/RH The only other choice I had was possibly a ZF or an E4OD since I could use a parking brake from a Superduty.
What will your final gear ratio be? (Tall, I presume to keep your highway RPMs down)
Are you staying with the original 2 speed axle (5.83/8.11:1)?
Take lots of pictures....I may still do it!!
Cheers,
Rick
Since I had a good (completely rebuilt, balanced and ported 292 I decided (reluctantly) to go with the 292. and I'm still using the E4OD (pics in the gallery)
Looks like you have the good engine too....(inline pump etc)
Old 06-13-2008, 05:34 AM
jaye's Avatar
jaye jaye is offline
jaye is starting off with a positive reputation.
Nice work! can't wait to see the final product
Old 06-13-2008, 12:08 PM
rustyrelic's Avatar
cummins conversion
I'll be using a fuller 5306 6speed non o/d out of a 95 f750 + 4sp aux trans with 15% overdrive.
the overdive only drops me 500 rpm. I'm looking for an Eaton rear end 15040s with 3.36 ratio and 6lug buds so I can keep my stock wheels. The 3.36 ratio will allow me to drive 60mph in 6th in the main trans and direct in the aux. trans at 1800rpm I know its tall gearing but I have two underdrive gears in the aux. trans if I need them..... on the parking brake the plan is to install a disc brake on the back of the aux. trans between the flange and yoke
Old 06-13-2008, 02:51 PM
HT32BSX115's Avatar
That should work good!
My problem was the 5 lug BUDDs that I have on mine. I have FAR fewer choices of axles to use. THe highest ratio EVER available for a 2 speed (5 lug) axle was 5.83 so I am limited.
With my 9.00-20 tires (40" dia), the 5.83 axle and the 0.71 OD in the E4OD I'll get about 2100 RPM at 60 mph.
That would have been a little fast for a 6BT for unloaded "cruising" down the highway.... I think they like to run at 1800 or less for highway cruising... It will however be perfect for my Y-block.
Did you keep the front engine mount cross-member and modify it for your engine or did you remove it and build your own? I am looking for a front engine mount for a V-8 (the cross piece).... My F-600 originally came with a 223 I-6.
Old 06-13-2008, 04:44 PM
rtcalabrojr's Avatar
rtcalabrojr rtcalabrojr is offline
Darksider
rtcalabrojr is starting off with a positive reputation.
Looks good! You must have used a shoehorn to get that in! LOL Keep up the good work and pics, we just love pics.
Old 06-13-2008, 05:10 PM
rustyrelic's Avatar
cummins conversion
I did reuse the stock front engine mount, I took 14in out of the middle and used 1/4 in plate to drop it 9in under the front crossmember .... picture in gallery
Old 06-14-2008, 01:48 PM
HT32BSX115's Avatar
I saw that. It looked like you might have just made another one.
I also thought about going to a power Stroke engine too but I just don't have the room on the left side. That steering box would be right in the way of the left exhaust manifold.
Did your 272 have a high mount water pump on it? or did your fan bolt directly to the pump? If yours is not a high mount pump and you have the water pump mounted fan and lower fan shroud, I'd be interested in the shroud if you want to sell it...
Old 06-14-2008, 07:31 PM
rustyrelic's Avatar
It's a high mount. I would like to find a good home for the y-block It only has 50k if you know anybody that looking for one send them my way
Old 06-14-2008, 07:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
That's interesting that the Cummins has bellhousing mounts, that will put the torque into the frame at a strong point. Did F600's have the doubled frame? The torque of the Cummins might have me worried about a stock frame!
Old 06-14-2008, 11:50 PM
rustyrelic's Avatar
The f600 is a single frame but it is 9in wide where the flywheel housing bolts to the frame, same as the f700 that I took the engine out of. I do have some concern because the f600 frame dose taper down going towards the front mount. The cummins has 175hp at 2500rpm and 450ftlbs torque. The picture is the f700 notice the leaf spring wore right through the frame
Old 06-15-2008, 12:25 AM
rustyrelic's Avatar
cummins conversion
I worked on a mount for my clutch linkage and shifter for the aux. trans today.. heres what I came up with
Old 06-15-2008, 12:29 AM
rustyrelic's Avatar
Transmission crossmember questions 682bear 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 01-06-2017 03:00 PM
Getting Ready: '58 F100 FE motor Martin Torres 1957 - 1960 F100 & Larger F-Series Trucks 0 08-02-2016 03:24 PM
CUMMINS CONVERSION CROSSMEMBER HACK ALTERNATIVES? ferrousFord 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-01-2016 12:34 AM
Motor Mounts 302 with MII fiftford 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 10-18-2015 08:44 AM
Tags
1955, 56, 600, conversion, cummins, diesel, drive, dump, f100, f600, fedex, ford, hood, swap, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
