Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Large Truck
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Is F-150 Still King?
  #31 (permalink)
Old 09-07-2008, 11:40 PM
rustyrelic rustyrelic is offline
rustyrelic is gaining momentum as a positive member of FTE.
56 ford f600 cummins converson
Since my last update I have installed the front clip,had a 18in driveshaft made to go from the 6sp fuller to the 4sp aux, worked on the interior, installed yblock water temp sender, heater, heater hoses, fuel sending unit so the stock ford gauges would work. No space for intercooler in front of radiator so I'm thinking of mounting it under the hood above the engine and using a factory hood scoop off a f700-800 big job to feed it cool air. Anybody know where I might find a hood scoop? Thanks for looking
  #32 (permalink)
Old 09-08-2008, 09:40 AM
WALFORD'S 56's Avatar
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 is starting off with a positive reputation.
I am getting ready to haul my diesel56 home. My buddy put an international in it instead of the cummings. I am not sure if that is what I wanted to do. I am now going to do the body and paint and at least it starts and runs. I wish he could have finished it complete. OH-WELL!!
I had a hood with air-scoop from a f700 and it is on a truck I traded. See if he will sell just the hood/scoop....Bill
  #33 (permalink)
Old 09-08-2008, 11:26 PM
Bill, I would love to see some pictures of your diesel conversion! Thanks for checking on the hood scoop ... Reno
  #34 (permalink)
Old 10-05-2008, 11:50 PM
cummins conversion
Started the cummins today (BIG GRIN) Mounted the intercooler over the engine will post picts as soon as I find my camera.
Still need to fab. a intake and air filter.
  #35 (permalink)
Old 11-03-2008, 12:16 AM
First test drive today! ran engine about 30min, drove around the block twice then a 2mile loop to run through all the gears....top speed with 6.33 gears 45mph. Im still looking for an Eaton 15040s with 3.36 ratio hyd. brakes and 6 hole bud wheels so I can drive at 60mph 1750-1800 rpm. 3 problems found, tach and speedo not working, leaking fuel filter. tach mag sensor faulty, speedo I don't know yet ... its a new cable with custom ends. order fuel filter
  #36 (permalink)
Old 11-03-2008, 05:31 AM
rtcalabrojr's Avatar
rtcalabrojr rtcalabrojr is offline
Darksider
rtcalabrojr is starting off with a positive reputation.
Keep up the good work! I like how you keep us posted. Glad to see someone else moving forward!
__________________
Roger
1955 F100
351c/c6 8.8 3:73 posi MII airbags
I smell cookies! click to check out the truck
http://s919.photobucket.com/albums/ad37/rtcalabrojr/
  #37 (permalink)
Old 11-03-2008, 08:40 AM
Great news!! I still have not gotten up and picked up my truck. I am glad you got a first run in!!! Bill
  #38 (permalink)
Old 04-28-2009, 11:45 PM
I finally found a dana 80 with 3.31 ratio out of a fed ex truck it has the correct 6 lug hubs so I can use my stock wheels. I'll be replacing the eaton 6.33/8.81 2sp. The dana will allow me to cruise at 60mph at 1750rpm. I hope to get this in the truck in late May when I get some time off work. (pictures in my gallery)
  #39 (permalink)
Old 05-31-2009, 08:18 PM
Installed the dana 80 but need to get two longer ubolts before I test drive. I worked on a driveline disc brake, made the disc out of 3/8in plate, mounted it on the rear flange of the aux. trans. bought a MB 2 caliper from The Street Rod manufacturing Co. Inc. Made a bracket to mount behind the aux. trans. Waiting on clevis yokes to make linkage to the stock floor mounted parking brake handle...... not having any luck posting the pictures sorry.
  #40 (permalink)
Old 08-05-2009, 11:48 PM
Driving the truck with the 3.31 gears is a dream come true! I was able to drive on the freeway without holding up traffic.. NOTE ... If you put a late model rear end with disc brakes on your truck that was 4 wheel drum brakes. You need to remove the check valve from the master cyl. because it keeps 10lbs of pressure in the lines and will cause the disc brakes to drag.( I found out the hard way) After removing the check valve install inline ck. valves 10lb for drum and 2lb for disc Mid Fifty sells the inline ck. valves and most speed shops have them too.
  #41 (permalink)
Old 08-06-2009, 04:30 AM
Darksider
Are pics still a no go for you? I cant get any to upload myself? I would like to see some latest pics of your truck, well anyways nice to see another truck back on the road. Keep up the great work and good luck as well!!
__________________
Roger
1955 F100
  #42 (permalink)
Old 08-06-2009, 10:17 PM
Quote:
Thanks
There are pictures in my gallery but I can't get them in the thread ... sorry
  #43 (permalink)
Old 08-14-2009, 11:10 AM
first mpg check = 20 mpg
Did my first mileage ck yesterday, combination of around town, stop n go, and freeway with 3/4 cord of firewood on the return trip. 141 miles , burned 7 gal. = 20 mpg. Not bad for a 10k truck I'm very happy with that. I was only getting 10 mpg with the 272 y-block.
  #44 (permalink)
Old 09-16-2009, 04:21 PM
vacuum pump
Installed a gear driven vacuum pump from a dodge truck (cummins powered) for my hydrovac brakes. It produces 27in vac ... much better than the 15in vac that the electric pump made. Now I can hit the brakes repeatedly and not deplete the vac. reservoir. I'm very happy with this modification.
  #45 (permalink)
Old 11-25-2009, 11:35 AM
2nd mileage check
14.6 MPG Took 2 months to rack up 303 miles. No freeway all in town, multiple short trips to hardware store, parts house, ect. I was having to much fun mashing on the go pedal and shifting gears!
Tags
1955 , 56 , 600 , conversion , cummins , diesel , drive , dump , f100 , f600 , fedex , ford , hood , swap , truck , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
