transmission shift points - Ford Truck Enthusiasts Forums
Old 06-13-2008, 01:58 AM
alberta04f150 alberta04f150 is offline
alberta04f150 is starting off with a positive reputation.
have installed an afe cold air intake also a bullydog programmer in an 04 fi50, have been suggested to firm up shift points, assuming this means to up rpms before shift ? also am going to dual up the exhaust, want to pull 8000 pd trailer occasionally but really am looking for the most jump i can get out of the 5.4 .
Old 06-24-2008, 04:03 PM
bigdavewilson bigdavewilson is offline
bigdavewilson is starting off with a positive reputation.
Quote:
Just came through Provost last week on my way to Saskatoon.
I am not familiar with the Bullydog programmers, but with my Diablosport Predator there are separate settings to increase the shift pressure and modify the shift rpm points.
Increasing the shift pressure has the most noticeable effect at wide open throttle and a lesser effect at partial throttle. My understanding is that firm shifts are better for the transmission.
So to directly answer your question, firming up the shift points and raising the rpm's of the shift points are two different processes, and both processes should be available to you. Often if your programmer manual does not describe how to modify the settings you can find instructions on line.
Hey before you get too excited about pulling an 8000 pound trailer very far, pull it over to the scales at Macklin and give yourself a little reality check. Run just the back axle onto the scale and then check the registered weight against the rear axle load capacity placard on the drivers door pillar. Bet you will find that you are WAY overloaded.
Old 06-24-2008, 04:09 PM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
As mentioned, firming up shift points is not raising the rpms. My edge has both parameters as well. Increasing the shift pressure, firms up the shifts. You are correct, a firmer shift is better from a trans durability standpoint
Old 06-24-2008, 04:16 PM
Just checked out the Bullydog site and they use the terms transmission tuning and transmission shift points. The transmission tuning will likely simply be a way to modify shift pressure for firmer shifts. In my experience do not be afraid to bump the pressure up to the maximum available, then if the shifts are too harsh back it down a bit at a time.
Is PCM Chip Memory a Real thing? Ezalycasaid 1994.5 - 1997 7.3L Power Stroke Diesel 1 09-12-2016 09:02 AM
F150 04 Auto Shift problem larrywcc 2004 - 2008 F150 0 08-30-2014 04:00 PM
C6 Shifting Problems...what fun TheKirbyMan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 01-10-2012 02:04 AM
Shift Points on 3.0 Ranger MNSubbie Ranger & B-Series 7 02-03-2008 12:10 PM
adjusting vacum modulator screw to adjust shift points on C6 behind a 6.9 liter bgodkin Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 11-07-2000 04:39 PM
Tags
08, 2004, 2008, bully, correct, dog, f150, firming, ford, mpg, point, points, recommendations, shift, shifting, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
