brake rotor size?
brake rotor size?
I know that in 1999 ford changed the thickness of their 4x4 front hub flange from 10mm to 13mm, and made up the differance in the rotor.
what i don't know is if they did the same in the rear.
i ask because i can get a kit w/ all 4 rotors (drilled/slotted) and pads
and i have newstyle front hubs to replace my bad one
so my question is will rotors for a 2000 will fit on my 1999 pre 3/22?
