Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-11-2008, 03:51 PM
parkland's Avatar
parkland parkland is offline
Garage is empty, add now
parkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to behold
Smile Fuel line specs needed for WVO conversion
specs on fuel supply to the heads...
I'm going for my WVO conversion.
I'm creating a complete second fuel system using a hydraulic pump for the WVO.
Now, I need to "Tee" into the existing fuel supply to the heads, what thread and size are they?
Also, I want to install a drain valve on each head, (where the fuel return was on buses etc), what size is that plug???
Thanks in advance.
******** language="JavaScript" type="text/javascript"> document.write('******** language="JavaScript" src="http://ad.doubleclick.net/adj/fordtrucks.tmus/category;category=Diesel__1999_-_2003_73L_Power_Stroke_Diesel;tile=4;dcopt=ist;sz= 300x250;ord=' + ord + '?" type="text/javascript">'); *********>******** style="display: none;" language="JavaScript" src="http://ad.doubleclick.net/adj/fordtrucks.tmus/category;category=Diesel__1999_-_2003_73L_Power_Stroke_Diesel;tile=4;dcopt=ist;sz= 300x250;ord=9352054344646146?" type="text/javascript">*********>
__________________
__________________
Such a cool little toy, for what it costs :
http://www.ford-trucks.com/forums/12...-it-costs.html
  #2 (permalink)
Old 06-11-2008, 05:51 PM
akghound akghound is offline
akghound is starting off with a positive reputation.
You need to study
Thanks in advance.
__________________
Not meaning to offend you, but:
Judging by your post I would say you haven't studied the WVO conversion idea very much. I guess you could "Tee" into the lines, "Drain" the return and such but there are better ways to do this. Check out how the VegiStroke is plumbed od look at the Frybrid information and you will have a much better idea on how to do this. Frybrid Vegetable Oil Fuel Systems and Dino Fuel Alternatives: Vegetable Oil Fuel Systems
Ken Gardner
  #3 (permalink)
Old 06-11-2008, 06:20 PM
03F2507.3 03F2507.3 is offline
03F2507.3 is starting off with a positive reputation.
How are you going to regulate the fuel pressure?
  #4 (permalink)
Old 06-11-2008, 10:25 PM
parkland's Avatar
Sorry, i didnt elaborate any there,
Where the line goes from the factory fuel bowl to the head, I'm putting a chack valve and also a check valve on where the WVO line T's into the normal line.
This way, if my WVO setup dies, truck rolls on without a glitchh.
I will run the WVO regulator slightly above the dino diesel regulator, as to close the check valves on the diesel lines and run on WVO provided pressure is adequate.
I want the drains on the heads to do an "emergency purge" if necessary.
The WVO will be regulated by a large adjustable fuel regulator i got for 20$. Already tried it, seems like it will work.
I actually already had a truck at one time running off WVO.
__________________
Tags
specs, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
