6.9-7.3 swap in 73-79 F250 4x4 - Ford Truck Enthusiasts Forums
Old 06-11-2008, 02:48 PM
Thunderjet4x4 Thunderjet4x4 is offline
Thunderjet4x4 is starting off with a positive reputation.
Been reading about swapping a 6.9 or 7.3 diesel into the dentside trucks, namely a 76 F250 4x4.
I seen the fordcummins site, and I personally don't like cummins, too noisy and they seem to belch alot of smoke. Besides that they are intended for dodges.
It's too bad Cat doesn't seem to have any 6.0-7.0 turbo V8's.
Or maybe I should just wait, fuel prices will kill everything's value soon, and could get a decent powerstroke 4x4 for cheap and leave my ol 76 as is.
After riding in a friends modded powerstroke, and he was having traction problems with 38's and auto trans on dry pavement-it was fun! Plus he still gets 18-22mpg.
Does anyone have some pics of any work done, or completed installs??
Old 06-11-2008, 05:12 PM
77F250Diesel's Avatar
77F250Diesel 77F250Diesel is online now
77F250Diesel is starting off with a positive reputation.
Here you go.........
[IMG][/IMG]
Dennis
Old 06-12-2008, 02:29 PM
Nice truck thanks for the pic! Do you happen to have any pictures of the motor mounts, or even just a shot underneath?
Any difficulties? what are you using for a fuel tank?
Old 06-12-2008, 03:04 PM
Pretty straight forward swap. Stock tanks, just weld/braze a tube to filler neck for return fuel.
Dennis
Old 06-12-2008, 03:21 PM
If you can weld/fab. you'll have no problems. Must use a diesel trans.
Old 06-12-2008, 07:02 PM
Thank you again! That does look simple-and damn tempting, hehe The older diesels must be really simple comparably to the new ones-less electronic gizmo's, altho the new ones crank out the power and mileage nice.
How is the power with that banks setup?
Old 06-12-2008, 07:23 PM
I'm very satisfied with the amount of power. The most of a load I've had on it was abt. 2000 lbs. in the bed and I didn't see much if any difference in accel..
The only thing I'm going to change will be an overdrive or od. trans. to bring the rpms down.
I'm getting 14-15 mpg around town, have'nt checked hwy. mpg. yet.
My Banks is the old non wastegate which I see maxing out around 10 lbs. boost.
Dennis
Old 06-13-2008, 02:17 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
I am in the process of putting a 7.3 idi non turbo in my 76 f-250. The swap is not hard. I am using a c-6 trans that mounted up in the stock location and used the stock driveline. I also am using front engine mounts on mine to avoid the hassle of side mounts. The stock front mounts are 120.00 new from ford. They were used in F-700 and F-800 trucks.
Old 08-09-2016, 11:26 AM
1979f250fool 1979f250fool is offline
1979f250fool is starting off with a positive reputation.
were you able to leave the original front cross member on the frame or did you modify it to get the motor to fit
Old 08-10-2016, 05:13 PM
The "stock" crossmember in mine is actually from a f150, my truck started life as a 2 wd f250.
I used all 150 bits because I wanted a coil sprung front end.
Update on power: I installed a mild (typ 4) cam, head studs, 4" exhaust, typ 4 compressor mod and a bull moose injection pump
which really woke the truck up.
will a zf5 work with a 6.9idi? VaFordman26 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 20 07-29-2015 04:09 PM
76 highboy powerstroke conversion Brycemunro 1973 - 1979 F-100 & Larger F-Series Trucks 15 01-08-2014 11:10 AM
87 F250 7.3 powerstroke swap fbj2012 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 26 07-30-2012 09:58 PM
Would a 7.3 Powerstroke fit in my 86 F-250? giantslayer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 10-26-2011 08:02 AM
Swap my 5.4 to the powerstroke Shawn66mcl 1999 to 2016 Super Duty 20 04-05-2011 11:58 AM
Tags
6973, 73, 7379, 76, 79, alternator, chopped, cummins, diesel, f250, f350, ford, fuel, highboy, mileage, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
