Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-10-2008, 09:48 PM
tomherrick tomherrick is offline
Garage is empty, add now
tomherrick is starting off with a positive reputation.
New Location for Dual Tank Switch - WVO
In order to reduce the amount of time required for the petro diesel purge, I want to install a new dual tank switch nearer the engine. I've spent some time today trying to determine a good location for the switch that's close to the lift pump (1990 F250 7.3). After disconnecting the existing switch near the forward tank, I'll splice the rear tank supply and return lines to those that run forward to the engine compartment. The forward WVO tank will get new supply and return lines. All lines will run forward to the relocated tank switch and from there to the lift pump and injector return lines.
So, anybody have their tank switch up near the engine? Where? Are you happy with the location and would you do it again? Options?
Thanks to all,
Tom Herrick
__________________
1990 F250 7.3 4x4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
