Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 06-27-2008, 11:51 PM
stractor is starting off with a positive reputation.
the problem you describe is also a symptom of a bad ignition module( the one on the side of the distributor) , ford had a recall on it in the early 90s. You could also have a problem with the The EEC Relay ( Electronic Engine Control Relay) This supplies power to the computer and if the contacts are bad (mine was full of water) the engine will die and may or may not restart or will not start at all. My guess would be the ignition module on the distributor. There was a problem with the solid state device failing when it was hot and restarting when it cooled off. If you can find the recall notices look it up.
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 06-28-2008, 02:37 PM
Here read this might help.
Ford Ranger/Bronco II TFI Ignition Diagnostics
  #18 (permalink)
Old 06-28-2008, 03:41 PM
feeniks4.9 is starting off with a positive reputation.
Quote:
Originally Posted by stractor View Post
Yeah, I think I found my smoking gun(from the Class Action Lawsuit linked to the article):
"..(the) TFI-IV module—which is an ignition-system component that Ford installed on the distributors of class vehicles—had an inordinately high propensity for failure due to overheating. The plaintiffs alleged that TFI module failure is more likely to occur in conditions that cause the TFI module to become overheated, such as in hot weather and while the vehicle’s engine is under load (such as while towing or while driving up a grade) or while idling for extended periods. The plaintiffs also alleged that TFI module failure frequently occurs on an intermittent basis; that is, the module will fail while hot, and then recover and continue functioning after it cools. "
Oh, sonofa....*bleep*!
This would be why it appeared to be related to cooling - I had replaced the module about five years ago, so I never even considered it when someone mentioned it earlier. As it happened five years ago, it never re-started when it died in the middle of a freakin' busy intersection, so the symptoms are completely different - and I see from your link that there are two different TSBs, one related to no restart, and one related to intermittent starting.
I replaced the part after a cop pushed me into the parking lot of a hotel (...so... embarrassing...), and I was good to go...
I am walking the line between being highly annoyed that this was the problem, and elated that this is the problem... I would hug you, you know, in a totally message-board-only way, if such a thing were possible... of course, the shop my truck is parked in is closed for the day, and they don't re-open until Monday morning... I'm going to be all twitchy until then.
I read the class action suit - but I can't find any TSB's related to the f-150 on this, do you know if one exists?
  #19 (permalink)
Old 06-28-2008, 06:04 PM
Yes -I have read the TSB when I had a subscription to Alldata. I don't know why the TSB's are such a closely guarded secret, possibly so someone can make money off them. Go here there is a wealth of tfi information as well as an interesting artical about the spout connector grounding (tsb issued)-poke around and read.
http://www.broncolinks.com/index.php?index=230
  #20 (permalink)
Old 06-30-2008, 11:08 PM
ElwoodMurphy is starting off with a positive reputation.
dtvperfect, I've noticed the same thing on my 92, I'll have to look for it, thanks for the info.
__________________
Doug
92 Flareside 4X4, 4.9, 5 spd
Nebraska Chapter Member
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
