Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 03-02-2002, 07:17 PM
Cerberus is starting off with a positive reputation.
Sub's in the read doors of an Excursion?
Has anyone done or seen an installation like this? I want to put some sub's in mine, but not sure how to go about it. Are there custom boxes out there?
'00 X, V10, toreador red
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-14-2002, 07:54 PM
todder53's Avatar
todder53 is starting off with a positive reputation.
Well i wouldn't put them in the doors. doors make to my noise. The thing is to get a box to put in the back and there are custom ones (its not hard to make them yourself). Or put them in the side panels in your truck in the back they do make panels that will fit right in there and be like ome. GO to www.crutchfield.com to find some of this stuff.
__________________
2001 F-350 Power Stroke
1978 Bronco
1977 F150
1963 F100
1969 Ford Mustang
  #3 (permalink)
Old 03-16-2002, 12:34 PM
Want to avoid a box and save the space. And there's no room in the side panels in the back. One side is taken up by the spare, and the other has the motor and ducting for the rear air. The doors just seem to be such a perfect spot. I think I'm going to spend the money and get custom fiberglass enclosures made for them and mount 10"s in them. I'll try and get pictures to everyone when I finish.
  #4 (permalink)
Old 03-18-2002, 10:54 AM
enduringexplorer is starting off with a positive reputation.
My brother has a 10" amplified tube sub-woofer from Kenwood. He uses this because it takes up very little space, sounds great, can be moved easily if he needs the extra space, plus it has a built-in amp which eases installation. If you put it right up against the back of the third seat, you still have a fair amount of cargo space. Remember, bass is non-directional. You don't need 2 subwoofers and you don't have to place them so they point at you. Anywhere in the vehicle is fine.
__________________
Tim M.
'03 F350 CC Lariat 4X4 PSD
'06 F150 Supercrew 4X4 5.4
'54 F800 Big Job
'64 F100 short and wide
'96 GMC Topkick, '89 International 9670
  #5 (permalink)
Old 03-18-2002, 12:08 PM
I don't think 1 10" will really be enough to fill such a big space with full sounding bass and not sound like it's straining the speaker. I'll go with a box if I absolutely have to, but right now it looks like an extra $200-250 for the custom fiberglass enclosures. I was just wondering if anyone knew someone, or had themselves, put the subs in the doors. A guy named erlong has, that posts on the excursion board has done it with fair results but didn't get custom enclosures. Thanks for the info though.
-Jase
  #6 (permalink)
Old 03-19-2002, 09:43 AM
Actually, the size of the speaker isn't really what matters. A lot of claims have been made about these sub-tubes performing much more efficiently than the standard subwoofers. Try visiting some of the manufacturers sites. I don't remember which site I looked at, but I saw a comparison of a 10" powered sub-tube out-oerforming 2 12" subs in a box. I can't speak from experience yet, though. I will be wiring my brothers sub into my Excursion in 6-8 weeks as a trial to see how it sounds. Then I will decide which way to go myself. Maybe you ought to try borrowing one from someone also to try it for yourself. Only your ears can decide if it sounds right for you. Your subwoofer should sound like it belongs with the rest of your system and not be overpowering, unless you like that downtown Detroit boom-boom sound.
__________________
Tim M.
'54 F800 Big Job
  #7 (permalink)
Old 03-21-2002, 02:09 AM
I've got a fair amount of experience with car audio and sub installations, and you're right about size not always being the most important. (We all try and convince ourselves of this all the time right? ) The truth is, it's really all about how the sub is ported and in what type of enclosure. Bass tubes do makes more sound, pound for pound and inch for inch, than most boxes. However, the bass is rarely clear and distinct, it's usually pretty muddy and cheap sounding. And there are really 3 reasons I'd go with 10's in the back doors: 1. They'll have more than enough power to fill the cab and not sound like they're straining. 2. 8's would probably look pretty sad in those big doors! 3. Just a perfect spot to mount them and not have to work around a box when loading gear up.
I was really hoping someone had done a good custom install on the doors so I could ask them questions. Erlong gave me some pretty good info, but I'm not going go the route he did. My amp will get mounted under the 2nd row of seats and I'll have fiberglass enclosures made and sound deadening fiberglass shot into the interiors of the doors to beef 'em up.
  #8 (permalink)
Old 06-14-2002, 08:49 PM
Just picked the Excursion up from Perfectionist Audio here in Anchorage. They did a great job and it sounds perfect. Not too much, not too little. Very balanced and I think the imaging from both speakers directly in the back compliments everything perfectly. Pics of the install are in my gallery.
  #9 (permalink)
Old 06-17-2002, 08:12 AM
mc71454 is starting off with a positive reputation.
  #10 (permalink)
Old 05-14-2008, 01:33 AM
Triple Ex is starting off with a positive reputation.
Copy cat system
Hi, My ex is in for the copycat to your system - I took the pictures from your gallery, loaded them onto my ipod and showed the tech what I was looking for, I elected to change all my factory speakers out with new Infintiy speakers, a new four channel amp to power these, a new 300 rms mono channel amp for the sub in the barn doors and a new JVC double din touch screen dvd head unit and twin alpine monitors in the headrests.....I think thats all.....
Whew.....um... anyone gonna have a place for me to sleep when "she who must be obeyed" finds out??
  #11 (permalink)
Old 05-14-2008, 09:55 AM
BradyCouchman's Avatar
BradyCouchman is gaining momentum as a positive member of FTE.BradyCouchman is gaining momentum as a positive member of FTE.
hey Cerberus you might think about getting some grills for the speekers if you think ol' Rex might get at them...
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
SoCal/Hawai'i FTE
Join our Chapter *HERE*
Quote:
Originally Posted by SteveBricks View Post
Brady "Bubba Redbeard" Couchman
  #12 (permalink)
Old 05-14-2008, 12:13 PM
bgalaxy67's Avatar
bgalaxy67 is starting off with a positive reputation.
Any good shop should be able to glass in a pair of 10's into the doors. I think you wouldn't have enough airspace for 12's Unless their the pancake types.
I took out the spare years ago and did a pair of 15's in there. Now the truck has 16 12's and is only used for shows.
__________________
If the listening level is too loud, promptly inform the driver, so he may pull over, and let you out
My Excursion
Wife's 250
  #13 (permalink)
Old 05-14-2008, 02:39 PM
Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.
turned out nice... I like it...
__________________
Don
: 12 volt specialist
1995 f-250 ext. cab, lb. 4x4, 5.8 5 speed. Performance mods, and a heavy foot.
Quote:
Originally Posted by STGFordCrazy04 View Post
X2 and hes not talking about truck nuts
Welcome to the Minions house.....Giving correct answers since 2007.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
