I ordered a set of 5 kit, 155.00 or so shipped. I don't worry so much about the typical 3 hoses on a brake system. I would almost be inclinded to split the rear brakes hyd. and make each rear hose independant off the frame to caliper. I think I'll be ok with the 5 hose kit from Russell SS braided.
I got my Russell kit # 696490 and the box says for a 4 in lift, although, the description doesn't state that? I don't want pigtails on my hoses. I'll let you know next week, Artie
Make sure you follow the directions for mounting them, don't (like I did) mount them the same way the OE lines came off.
I've not been real happy with the brake feel. It's a bit spongy or rather, take a bit more pedal to initiate the brakes. I was reading the F-150 forum and stumbled across a fix. ( https://www.ford-trucks.com/forums/7...-resolved.html )
OK this is a really old thread but I printed it months ago and just had to say - great information once again. I did this today took all of 10 minutes, went about 1 full turn and brakes are much improved! Thanks Monsta
did you do the nut adjustment or the braided lines? i did the nut adjustment three years ago and its still perfect but with 106k on the clock its time for new hoses so i was thinking about braided ones
I did braided lines but not the nut took me a couple hours but I was doing the parking brake shoes (due to the parking brake spring exploding) and new hub seals bearings etc.... I am not sure I would want to adjust the nut my brakes feel very solid.
Ever since I have owned my truck the brake pedal goes almost half way down before engaging. I have had all the brakes replaced, fluid flushed and still never got a good pedal. I have had everything inspected and always told everything is ok. I have had a couple times where I almost got in trouble because of it. I am thinking this is the next best route.
