1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Upper exhaust pipe bolts from manifold?
Old 05-02-2017, 04:07 PM
jpilk99's Avatar
jpilk99
jpilk99 is offline
I'm trying to drop the exhaust pipe, (on the driver side), away just enough to inspect/replace the gasket between it and the back of the exhaust manifold. (I was about to start working on the exhaust manifold gasket when I could feel exhaust coming out at the seem of the upper pipe. Maybe I get lucky and THIS is my only leak area).
Anyhow, I lathered both nuts/bolts with PB blaster, and then put a torch to one of the bolts ...and snapped it clean off. Moved to the other nut/bolt, same thing.
I have replacements, so I figured "no big deal". But, I cant get the old/broken bolts/studs out. Should I just get a bigger hammer and more PB blaster?
Thanks in advance!
Jay
iron1951
04-12-2017 03:45 PM
Dave145
05-10-2013 10:55 AM
gray91
General Automotive Discussion
11-29-2007 04:35 PM
mfriesen
1983 - 2012 Ranger & B-Series
07-08-2006 09:04 AM
jseim44
01-10-2006 09:11 PM
Quick Reply: Upper exhaust pipe bolts from manifold?
