Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-09-2008, 06:31 PM
jlank is starting off with a positive reputation.
Wishy washy AC
My ac can't seem to make up its mind. It'll blow cold then a little warmer than cold again. Could I be a little low on freon.
Thanks
Joel
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-09-2008, 07:36 PM
wresleu is starting off with a positive reputation.
Most likely. Go buy yourself a bottle of refrigerant, and make sure you get the kind with the oil/sealant just in case. Use the kind with the built in gauge, and check your freon level before you add more. The problem could be elsewhere but I doubt it.
__________________
2003 Explorer XLT 4.0--the wifes ride
1996 Ranger Supercab 4x4 3.0----retired
1994 Aerostar Cargo 4.0---rearended
2000 F150 Lariat 4x4 Off Road--retired
2006 Ranger 4.0 FX4 Auto
  #3 (permalink)
Old 06-09-2008, 07:38 PM
Thanks I just posted to your stealership post!!
  #4 (permalink)
Old 06-09-2008, 10:30 PM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
Quote:
Thanks
Joel
Not very likely. If the refrigerant level were low, it would not change temps...
More likely, it's either a blend door or clutch gap issue. There are other possibilities, but a low charge is not very likely.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #5 (permalink)
Old 06-10-2008, 10:31 AM
KingRanchMan02's Avatar
KY KR lover
KingRanchMan02 is gaining momentum as a positive member of FTE.
Project is right. Temperature fluctuations are not likely to be a low freon problem. Is the compressor short cycling at all? Is the complessor clutch noisy?
__________________
John
aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege
5.4L 3.55 LS, 4x2
Diablosport Predator Programmer, K&N filter.
`08 Sable Premier
Merlot Metallic, Black leather
3.5L Duratec, 6 speed automatic
  #6 (permalink)
Old 06-10-2008, 03:49 PM
I was experiencing the same symptoms just last week. I bought a can of freon, checked the level, it read low, so I added to the appropriate level, and all has been fine since. However the compressor does seem to make some weird grinding noise still. So apparantly I may have a leak.
__________________
  #7 (permalink)
Old 06-10-2008, 06:48 PM
Quote:
It's also likely that it's improperly charged and/or is starving for oil.
Steve
__________________
  #8 (permalink)
Old 06-10-2008, 07:54 PM
Doesn't seem noisy or like it's kicking on and off. It's just a little warmer then it should be. All 3 other trucks I've owned would freeze you out of the cab. Maybe the extra volume of the extended makes a difference, LOL.
Thanks for helping
Joel
  #9 (permalink)
Old 06-10-2008, 08:24 PM
Sorry to hijack the thread...but projectSHO when you say starving for oil, is there a ratio that is supposed to be met? Would the system need to be drained down and refilled to guarantee that ratio be met?
The reason I ask is this, I bought the kind of freon that has the oil/conditioner mixed in, and just assumed it would be the proper ratio of freon to conditioner/oil.
__________________
  #10 (permalink)
Old 06-11-2008, 06:21 AM
There is a proper volume of oil that the system requires.
Once a system has leaked or has opened, it is impossible to know exactly how much lubricant is in the system although an educated guess can be made based on what has occurred.
The only way to know for certain is to flush the entire system out, drain the compressor, replace the accumulator, and to fill the system from scratch with the correct amount of oil and to charge the system with the specified weight.
Anything else is a guess.
Steve
__________________
  #11 (permalink)
Old 06-11-2008, 09:19 PM
NEBFRD is starting off with a positive reputation.
DO NOT use the leak sealer crap!!! That stuff plugs orifices and driers. I have dealt with this time and time again. I know that the advertisement looks good but the only things that are supposed to be in a refrigeration system are oil and refrigerant.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
