Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-09-2008, 04:39 PM
dyceskynes is starting off with a positive reputation.
Brake Light Socket
Where can i get a brake light socket for a 92 Aerostar. I checked a few places online but the pictures they show is different than what I have. Neither of my brake lights are working. On the right side if i press on the side of the bulb the brake light portion works but if i tap it it stops. The parking lights work the whole time. Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-09-2008, 05:16 PM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
You can get them from a junker vehicle. Otherwise, I'm not sure what to tell you.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #3 (permalink)
Old 06-09-2008, 06:26 PM
rebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to behold
I would be surprised if a socket for a Bronco II or Ranger did not fit. Do you have a picture of your lens socket?
__________________
The Year 2008 Anno Domini -
May it bring a great year of Revelations to you.
  #4 (permalink)
Old 06-10-2008, 11:47 AM
No I do not have a picture of them, but I do have the sockets out of a doner vehicle. Not sure what shape those are in but I guess I will need to find out. In worse case I will try to retro fit some LEDs in there somehow.
  #5 (permalink)
Old 06-10-2008, 02:22 PM
lv2race is starting off with a positive reputation.
Sounds like they are dirty or corroded. Try cleaning them up with a wire brush or some sandpaper, then apply a small amount of dielectric grease to the contact areas.
__________________
J Lowe
'90 F-150, 4.9
'00 Expo, Triton 5.4
  #6 (permalink)
Old 06-10-2008, 03:43 PM
taurus8's Avatar
taurus8 is starting off with a positive reputation.
Do they look rusty? If so, you may replacing them in 6 months time again because you might have a leak in the tail light. After you replace them, check the seal...
My right light one would leak just a little whenever I filled up the rear windshield washer fluid. A little caulk cured that...
__________________
John.
1992 LWB Aerostar XL
  #7 (permalink)
Old 06-10-2008, 03:46 PM
xlt4wd90 is starting off with a positive reputation.
Quote:
I think we've covered the retrofit LED bulbs here before. In general, they are terrible for replacing standard bulbs; they do not put out enough light, and they do not have the proper distribution.
If you want to install LEDs in your brake or signal lights, you should design something that will work with the housing and lenses, like the manufcturers do with their cars.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
