Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-09-2008, 02:57 AM
CrazyHorseUK is starting off with a positive reputation.
No power!
Hi, just rebuilt my 93 351w after a coolant problem, replaced head gaskets.
She will start on first turn and idle fine but if you give it some gas it won't rev smoothly and when you take your foot from the gas the revs don't drop off straight away, when I take her on the road there is no power at all and it dosn't sound right.
I'm pretty sure I have all the pipes in the correct places.
Any suggestions would be greatly recieved as in England there are very few garages which will look at American vehicle let alone that I would trust.
Allan
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-09-2008, 05:29 AM
dragogt's Avatar
dragogt has a very good reputation on FTE.dragogt has a very good reputation on FTE.dragogt has a very good reputation on FTE.dragogt has a very good reputation on FTE.
Check your Timing, sounds like that could be off.
__________________
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
Aaron -STG's - Pirate Investigator
Im fabbergasted![/quote]
Quote:
Originally Posted by STGFordCrazy04 View Post
these tires bring the epic suck!
They are thornbird wanna-bes! Which is quite possibly the most derogitory thing someone could say about a tire sold for offroad purposes.
  #3 (permalink)
Old 06-10-2008, 03:57 AM
I didn't touch the dizzy or the chain, is there anyway it could have altered? any idea's?
Allan
  #4 (permalink)
Old 06-10-2008, 09:40 AM
ksubigbuck is starting off with a positive reputation.
What noise is it making?
I'd check the timing just to be safe. Should be 10*BTDC
  #5 (permalink)
Old 06-13-2008, 02:21 AM
I will take a look tomorrow (Sat) and recheck the timing, do you not think it could be something on the air pipe side or egr?
Allan
  #6 (permalink)
Old 06-13-2008, 08:26 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Sounds like you may have an air leak or vacuum leak. Use an unlit propane torch to spray gas around the gaskets between the upper and lower intake, lower intake and block, and any vacuum lines at the intake. If the motor revs you have found a leak.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #7 (permalink)
Old 06-14-2008, 03:25 PM
Hi, thanks for the idea's, I have checked the timing and that is fine(could not do the propane thing as it's in a van and there's not a lot of room and you can't tell if the gas is being sucked in the carb). I have removed the upper and lower inlet manifolds which seem fine but cannot rebuild because couldn't get any new gaskets, hopefully they will arrive next week and i will try again, any idea's of checks to do while they are off to save time later? or parts to change which could avoid earlier problem?
Allan
  #8 (permalink)
Old 06-14-2008, 07:22 PM
Beanscoot is starting off with a positive reputation.
First of all, my condolences for working on an engine in a van.
Double check the routing of your high tension leads, the 351W uses the firing order of 1-3-7-2-6-5-4-8.
Cylinders on right bank are numbered 1-4, front to back and 5-8, front to back on left bank. This is the same as some 302s, but early 302s used a different firing order, so sometimes there can be errors.
You could have proper timing at #1 cylinder and still have the firing order mixed up.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
