What are the widest tires i can fit?
Old 06-08-2008, 10:04 PM
OldBlue68's Avatar
OldBlue68
OldBlue68 is offline
i have a 1968 f100 2wd stock suspension..im tryin to get some nice beefy tires..whats the widest i can go ?
Old 06-08-2008, 10:22 PM
seafire's Avatar
seafire
seafire is offline
Old Blue, it all depends on the profile your are looking for. Do you want 60 series or 50 series? When I worked as a tire toad. The widest tire that I could fit on a 2wd at that time was a 255/60R-15. I did see people put on 275/60R-15. However, they did rub when they turned to sharp.
Seafire
Old 06-08-2008, 10:28 PM
Power Smoker's Avatar
Power Smoker
Power Smoker is offline
I know of a stock '67 F-250 2WD running 285/75r16's, about 32" tall, and the front's pretty tight, but the back's got plenty of room. I think you could fit the 285's. most tire shops will let you "try before you buy" to make sure. It's at least worth asking. wheel offset can make or break the look though. The more offset, the further the wheel sticks out or in. Max tire width will depend on the wheel you run. The best way to be sure is test fit.
Last edited by Power Smoker; 06-08-2008 at 10:31 PM. Reason: didn't finish making point
Old 06-08-2008, 10:50 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
I have 285/75R16s on the rear of my 69 on stock steel rims from an 84 F250, and they fit with about 3/4" on either side. I wouldn't run that wide on the front, though. I ran 245s on the front before, and it was a little tight, but it also tracked poorly and was a royal pain to steer. I have 235/85R16s up front now, and they are great.
Narrower tires give better fuel mileage too-
Old 06-08-2008, 11:45 PM
wildwes's Avatar
wildwes
wildwes is offline
i am thinking about putting 31x10.50R15 tires on the back of my 69 f100 2wd, will they clear the top of the fender wells if I load the truck down with hay/firewood/etc, to the point that the springs are bottomed out, or would they rub?
Old 06-09-2008, 12:02 PM
OldBlue68's Avatar
OldBlue68
im looking to rake this truck, these tires will be for performance..so im looking for narrow in front big and wide in the back
Old 06-09-2008, 12:20 PM
BradyCouchman's Avatar
BradyCouchman
BradyCouchman is offline
i got 33X12.5 all around and the back there is lots of room, but it is very close in the front, dont rub on roads but when i go down dirt roads with bumps i will hit the fender if my wheels are turned.
Old 06-09-2008, 02:25 PM
Fritolay's Avatar
Fritolay
Fritolay is offline
i run 31x 10.5's on my f100 4wd have never had a problem with rubbing anywhere and i have had the back severly overloaded several times.
Old 06-09-2008, 06:40 PM
custom cabby's Avatar
custom cabby
custom cabby is offline
tire size
i am running 275/60/15 on 15x8 and 195/60/15 on 15x6 and have a lowered rake all the way around. and i have no rubbing at all with approx. a 4-6 drop.
Old 06-09-2008, 08:29 PM
ken selvy's Avatar
ken selvy
ken selvy is offline
Just dont forget about diameter of rear tires , smaller will give you more rpms and less gas mileage , I am running 28 inch rear tires 275,60s 15s on 10 inch rims and 8s up front with 235,60s 15s . I am going to buy different rims with a 5 inch backspace to tuck in my tires in the back and run 6 inch up front . Then run a 29 inch bf tire on a 10 inch rim in back .
Old 06-09-2008, 10:45 PM
wildwes's Avatar
wildwes
wildwes is offline
thanks for the info, i was just wondering, i have never ran 31x10.50 before, i usually run 225/75r15 on the front and 235/75r15 on the back of all of my old trucks, and i wanted to make sure that the 31s wouldn't rub, since i plan to haul a lot of hay and firewood in it and will have the springs pretty much maxed out.
Old 06-09-2008, 11:14 PM
f2501967's Avatar
f2501967
f2501967 is offline
im currently running 33x12.5/16.5 out back and 9.5x16.5 on the front.
when i have a pallet of salt on the truck it gets very close to rubbing.
once before i had 2 pallets of salt, every time i turned the chrome molding would rub/cut into the tires. i removed the chrome.
now i know only to carry 1 pallet of salt at a time. dont need slicing into tires since i have no spare, and no place to put one. lol
Old 06-12-2008, 07:24 PM
Wolf0r's Avatar
Wolf0r
Wolf0r is offline
31"s look and ride great. I ran them on the 69 I used to have. Of course I never hauled much in it either.
Old 06-16-2008, 08:41 PM
lance65's Avatar
lance65
lance65 is offline
Right now I have 295-50-15(N50x15) on the back w/8" rims. I am going to be taking them off cause I think they are too short, but are nice width. I am probably gonna get 295x65x15 and the same height in front w/ a 245x75x15 on 6" rims.
-Lance
Old 06-16-2008, 09:20 PM
wildwes's Avatar
wildwes
wildwes is offline
i think i'm going to forget about the 31x10.50 15's and put 30x9.50 15's instead, so i don't have to go with wider wheels. I want to stick with stock rims.
bobkonaben
02-03-2015 09:04 PM
cws10190
04-22-2012 11:31 PM
four.six
05-18-2010 09:40 AM
5.8F250
09-07-2009 04:20 PM
0007
1997-2006 Expedition & Navigator
07-01-2009 04:17 PM
Quick Reply: What are the widest tires i can fit?
