*** Soft Brake Pedal Resolved *** - Ford Truck Enthusiasts Forums
Old 06-08-2008, 04:34 PM
bcrab bcrab is offline
bcrab is starting off with a positive reputation.
Exclamation *** Soft Brake Pedal Resolved ***
I found this at another site. I tried it on mine and it worked like a charm. No more spongy brakes.
Hope this helps...
*** Soft Brake Pedal Resolved *** - F150online Forums
Old 06-08-2008, 05:23 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Why not just tell us what the fix is instead of linking to a 14 page thread so everyone reading doesn't have to read 14 pages to determine what everyone in the thread ends up agreeing to? Just food for thought....
Old 06-08-2008, 05:45 PM
Quote:
Its something that I can't take credit for and I thought people might want to read through the results others have had before trying it their selfs.
Anyway here it is.
Quote:
Here are the steps I took:
-Remove the two nuts holding the master cylinder to the brake booster, they are 1/2in bolts.
-Once the nuts are removed, slide the master cylinder straight away from the brake booster. As I mentioned before there will be alot of resistance due to the vacuum build up. You can rock the master cylinder back and forth and you will here the vacuum relieving, once it does you can slide the master straight back.
-Locate the rubber o ring and ensure it is still in place. It fits between the master cylinder and the brake booster.
-With the master cylinder pulled back(leave all lines and wires attached) just position it out of the way. You will clearly see a 7mm bolt that is threaded into the rod sticking out of the brake booster. The rod has a grooved shaft that you will need to hold with needle nose pliers to keep it from turning while backing out the 7mm bolt.
-Back the 7mm bolt out of the rod(counter clockwise) about 1/2 turn or how much you see fit. I tried half turns until I got the brake pedal to where I wanted it. It is possible loosen the bolt to much to the point where your brakes will drag, thats why I went in such small increments. It took mine about 1.25 - 1.5 turns to get it right.
-Bolt the master cylinder back in place and your done.
Old 06-08-2008, 07:01 PM
FTE Ken's Avatar
Thanks... I'm going to try this on my truck, I don't care for the brake pedal feel at all!
Old 06-08-2008, 10:07 PM
garman garman is offline
garman is starting off with a positive reputation.
i did this fix. after two visits to my dealership about a soft brake pedal, which all they did was bleed my air lines. after 3 and 1/2 years of dangerous brakes, i saw a tread about this rod behind the m/c. i removed the m/c, put needlenose plyers on the rod and backed out the nut one full turn.(counter clockwise) my brakes firmed up to the point that when my foot touches the brake pedal it stops. what a concept. just so you know my brake pedal was very soft, so others might not need one full turn. it worked for me good luck, garman 2004 S/crew lariat
Old 06-09-2008, 12:06 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
I read the linked thread when it first got posted over there...and I've always wondered what you guys are feeling?
maybe I don't have it, or I just don't notice?
Old 06-09-2008, 08:56 AM
f-150 on 22's f-150 on 22's is offline
f-150 on 22's is starting off with a positive reputation.
Will you need to bleed the brakes or anything special? I notice it said to not disconnect anything so I am guessing you will not have to do it.
Old 06-09-2008, 11:41 AM
Quote:
Nope.
Its so simple and easy to do. It only takes about 15 minutes to adjust. Just don't back out the rod bolt to far or the brakes will catch. I marked the bolt with a sharpie and only adjusted about a 1/4 turn at a time till it felt right. Take it for a test drive after each adjustment. I used a stick to push the pedal down to push the rod out to make easier to adjust.
One more thing - With the truck off pump the brakes a couple times, it uses up the vacuum thats left in the mc then it slides of real easy.
Old 06-09-2008, 12:46 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
hum...i've never considered the brakes on our trucks spongy......maybe i've just driven too many chevy's...LOL
Old 06-09-2008, 01:00 PM
FTE Ken's Avatar
My brakes are very spongy. I driven other 2004-2008 F150s and most have much firmer brakes than mine.
Matt983's Avatar
Matt983 Matt983 is offline
Matt983 is starting off with a positive reputation.
I noticed my truck had squishy brakes right away when I first test drove it, kinda scared me. Gotten used to it now but this quick fix sounds pretty intriguing might give it a go if I have nothing else to do today.
Old 06-09-2008, 07:02 PM
broncobilly66 broncobilly66 is offline
broncobilly66 is starting off with a positive reputation.
nice post...i'm gonna thy this.. gotta love this site
Old 06-09-2008, 07:13 PM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
I'm definitely going to do this to mine. I have always complained about my spongy brakes and have hated them from day 1! Great info!!
Old 06-09-2008, 07:38 PM
FTE Ken's Avatar
All done and the results are great. Took much longer than 15 minutes on mine because the Roush air filter box is very large and needs to be removed to pull out the master cylinder. Took a couple of adjustments before it felt right.
Old 06-10-2008, 02:18 PM
V8EXPLR V8EXPLR is offline
V8EXPLR is gaining momentum as a positive member of FTE.
Hmm. My brakes just started getting spongy since 5/30, so I may have to look into this. The truck is at the dealer right now looking at the brakes, an rpm/tach/performance issue and an oil change/tire rotation. So if they don't fix the brake issue, I'll have to try this. Wanted to make sure my brake issue wasn't due to the recall either.
Improve your brake feel. Monsta 1999 to 2016 Super Duty 52 09-15-2016 01:53 AM
Soft brake pedal normal for IDI trucks? Kuhns71 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 08-22-2016 01:22 AM
Brake pedal sucks down when pushed down. myfeetrock 1987 - 1996 F150 & Larger F-Series Trucks 4 01-22-2015 10:55 PM
Wooshing sound when you step on brakes reno138 1987 - 1996 F150 & Larger F-Series Trucks 8 03-13-2014 09:12 AM
1982 F-250 4X4 Brake Problems threewhln 1999 to 2016 Super Duty 2 07-04-2013 08:55 PM
Tags
01, 1995, 2000, booster, brake, expedition, f150, f250, f350, ford, issue, mushy, pedal, soft, squishy, windstar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
