*** Soft Brake Pedal Resolved *** - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 07-23-2014, 02:55 PM
ocastellan ocastellan is offline
ocastellan is starting off with a positive reputation.
why no photos
  #32
Old 07-23-2014, 03:50 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Because it's a 6 year old thread so the links to the pics are no longer current.
Stewart
  #33
Old 07-24-2014, 11:26 AM
thewheelman's Avatar
thewheelman thewheelman is offline
thewheelman is starting off with a positive reputation.
And it's still a problem.....my 05 has just crossed 130k on the clock and every now and then I think the pedal is going all the way to the floor........
  #34
Old 10-29-2014, 07:05 PM
tommyt tommyt is offline
tommyt is starting off with a positive reputation.
Hoping someone can help.
My 2004 Expedition has the same problem however, instead of a screw on the end of the rod inside the break booster, there is a nipple with a pin (see attached picture) Thinking it also turns out like the screw, I grabbed both the rod and the nipple with two pair of needle nose and wilst trying to turn it immediately bent the pin on the nipple.
The nipple is made out of aluminum and has a little pin that inserts into the rod inside the break booster. The pin is split like a cotter pin and is friction fit inside the rod.
When I bent the pin, I tried to bend it back but aluminum doesn't like to bend and so half of the split pin broke off and the other half is cracked. JB Weld is out of the question as I feel it will eventually break causing a serious break malfunction.
Now the dealer doesn't just sell the nipple even though it is easily bent broken or lost. They want you to buy a whole new booster.
Does anyone sell just the nipple? Or maybe a mechanic on these boards may have one laying around in their tool box? I already checked my local dealer.
Any other suggestions?
Thanks.
Improve your brake feel. Monsta 1999 to 2016 Super Duty 52 09-15-2016 01:53 AM
Wooshing sound when you step on brakes reno138 1987 - 1996 F150 & Larger F-Series Trucks 8 03-13-2014 09:12 AM
1982 F-250 4X4 Brake Problems threewhln 1999 to 2016 Super Duty 2 07-04-2013 08:55 PM
1999 F150 ANOTHER SOFT PEDAL PROBLEM, HELP!! CAPTUPER 1997 - 2003 F150 14 03-27-2013 10:53 PM
1990 F 350 soft brakes nmichael 1987 - 1996 F150 & Larger F-Series Trucks 9 06-02-2011 12:25 AM
Tags
01, 1995, 2000, booster, brake, expedition, f150, f250, f350, ford, issue, mushy, pedal, soft, squishy, windstar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
