*** Soft Brake Pedal Resolved *** - Page 2 - Ford Truck Enthusiasts Forums
Old 06-10-2008, 07:36 PM
pohlmeyr pohlmeyr is offline
pohlmeyr is starting off with a positive reputation.
This is what i did when i first got my truck. My wife was kinda upset i was already working on it.
The fix for "Mushy brake pedal feel" is quite simple. Most of the ford vehicles i have owned needed this fix done.
There is a shaft that is adjustable behind the Master Cylinder and is attached to the brake booster. You need to take off the master cylinder but DO NOT remove any of the master cylinder brake lines (Be careful not to bend any). There is enough room to move the master cylinder out of the way and not remove the lines. Be careful not to lose the O-ring that seals the master cylinder to the Brake Booster. It will be kinda tough to remove at first because of the vacuum that is still in there. The 2 nuts that need to be removed are 1/2". After the master cylinder is removed use a 45* or 90* needle nose pliers to hold the splined shaft and unscrew the 7mm bolt on the end of the shaft. This makes the rod longer which engages the brakes sooner. I unscrewed mine (2008 f150 4x4 screw) 3/4 of a turn and it seems to be about right. I took mine for a test drive and then jacked up the front of the truck and spun the tires to see how much drag i had. If you unscrew the bolt too far it will keep the brakes engaged and you will have a warped rotor or a lot of brake dust . If you look at the pictures i used a paint pen and marked the top of my socket so i knew how far i had unscrewed the bolt. Assemble in the reverse order. If you have any questions or this doesn't make sense let me know and i will try to further explain. Good Luck!!!!
Old 06-10-2008, 08:14 PM
bcrab bcrab is offline
bcrab is starting off with a positive reputation.
If you give the breaks a couple of pumps with the truck off before you start theres no vacuum. Easily pulls right off.
Old 06-10-2008, 09:28 PM
Good point!
Thanks
Old 06-12-2008, 12:20 AM
hoover85 hoover85 is offline
hoover85 is starting off with a positive reputation.
Same Problem
Hi guys, my dad has an 04 f-150 and he just brought it to my attention that his brake pedal feels soft. I read about adjusting the pushrod but it feels like a bad master cylinder, and why would the pushrod all of a sudden need adjustment? Have you guys had bad pedals from day one or is it something that happened suddenly?
Old 06-12-2008, 12:43 AM
Mines been mushy since I bought it.
Old 06-13-2008, 05:58 PM
garman garman is offline
garman is starting off with a positive reputation.
my 04 s/crew was soft from day one
Old 06-13-2008, 05:59 PM
but not now! what a simple fix, i wish the dealer would have done this years ago.
Old 06-13-2008, 06:03 PM
My brand new 08 F150 was mushy when i drove it off the lot. When i asked the salesman about it he sad that is just how they are. My 99 windstar and 95 f150 both also had mushy brakes. I did the same fix to both of them and problem gone.
If you have had good firm brakes and then they fade that is a different problem probably related to a leaking master cylinder internally or a leak in the system somewhere.
Old 06-15-2008, 03:45 PM
broncobilly66 broncobilly66 is offline
broncobilly66 is starting off with a positive reputation.
I just did the brake pedal mod ... what a differance.. best 15 min. job ever, BTW I turned mine out 1 full turn.. jacked up the front after test drive & no brake draging ... good luck
Old 06-27-2008, 10:02 AM
thewheelman's Avatar
thewheelman thewheelman is offline
thewheelman is starting off with a positive reputation.
I looked at the other forum post, cut and pasted it into a format that I thought my dealer would understand and clipped it to my keys when I dropped the truck off Wednesday night. They called me by 10 Thursday morning saying the truck was ready to pick up! Wow! I've got brakes!!!!! BTW, this is an '05 SCrew that's still in warranty. They replaced the MC for me less than a month ago and I still had the same ol' spongy brake feel. This fix works! Take some form of description of it with you to the dealer and it will work! The post I used I think had more credibility than saying, "Some guys on line said....." because it has a service manager's name, dealer name and phone number on it.
THANKS!
Old 06-27-2008, 10:34 AM
Good... Glad it worked. I copied it to here for just that reason. The more people it helps the better.
Old 06-28-2008, 06:25 PM
fitz888's Avatar
fitz888 fitz888 is offline
fitz888 is starting off with a positive reputation.
My 2008 has the same problem sometimes i think its not gona stop im will try this . good info!
  #28
Old 03-23-2009, 10:08 PM
Bananarama Bananarama is offline
Bananarama is gaining momentum as a positive member of FTE.Bananarama is gaining momentum as a positive member of FTE.
My wife complains about my 2000 excursion having the same issue. I am gonna try it!!
  #29
Old 03-23-2009, 11:07 PM
Funny this should come up again. My brake pedal has gone soft again. When I ease to a stop, it sinks further down than the gas pedal. Since they've addressed it twice under warranty, think they'll cover it under warranty again? I've got 47k on the truck.
  #30
Old 05-01-2012, 10:34 PM
yelbike yelbike is offline
yelbike is starting off with a positive reputation.
Am I in the right spot? I didn't see the adjustment in there? What did I do wrong? The shaft does turn freely and has about 3/8" slack back to front.
Help.
Improve your brake feel. Monsta 1999 to 2016 Super Duty 52 09-15-2016 01:53 AM
Soft brake pedal normal for IDI trucks? Kuhns71 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 08-22-2016 01:22 AM
Brake pedal sucks down when pushed down. myfeetrock 1987 - 1996 F150 & Larger F-Series Trucks 4 01-22-2015 10:55 PM
Wooshing sound when you step on brakes reno138 1987 - 1996 F150 & Larger F-Series Trucks 8 03-13-2014 09:12 AM
1982 F-250 4X4 Brake Problems threewhln 1999 to 2016 Super Duty 2 07-04-2013 08:55 PM
Tags
01, 1995, 2000, booster, brake, expedition, f150, f250, f350, ford, issue, mushy, pedal, soft, squishy, windstar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
