Pulstar Spark Plugs
Old 06-08-2008, 12:48 PM
twroper's Avatar
twroper
twroper is offline
Pulstar Spark Plugs
HAs any one tried these new Pulstar spark plugs?
Old 06-08-2008, 07:46 PM
ReAX's Avatar
ReAX
ReAX is offline
To change the power out put, it has to either reduce the amps or the voltage so it can increase the other. So either it is a gimick to boost their resistor plugs or it has some kind of transformer. Either way, I'd rather do the same thing with an MSD or like ignition upgrade.
Old 11-06-2008, 09:44 AM
WestxSRT10's Avatar
WestxSRT10
WestxSRT10 is offline
I saw a test done with these plugs on "HorsePower TV", they gained 6 hp peak on the dyno. At $25 a plug ($250+) a set dosn't seem worth it.
Old 11-13-2008, 09:35 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Considering the user has two posts, both about these plugs, I'd say its spam. Change any worn out plug and you're going to see similar improvements, no matter what you change them to so long as the gap and heat range is correct.
Twistedwrench
04-01-2012 05:17 PM
Breaker 1-9
03-10-2012 03:54 PM
GRNMSTR
Escape & Escape Hybrid
07-03-2011 03:39 PM
iamme81702
10-13-2010 08:31 PM
pud
11-28-2008 03:49 AM
Quick Reply: Pulstar Spark Plugs
