You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
What should good used oil titrate at? what is the ph where we should look elsewhere? I am going to start titrating oils from different places tomorrow to see what values I come up with.
__________________ Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!! 2002 TDI New Beetle - also likes Bio.
My oil has never titrated greater than 1.7, I would say anything at 2.0 or less is good. The other thing to look for is water, take some samples home and do a water test on them. Quantitative Water Test - Collaborative Biodiesel Tutorial
I've done testing in my lab with a lab scale ( weigh sample, boil off water, re-weight ) and have found that anything over 2 percent water can cause problems. Excess water will combine with the Lye in a side reaction, which lowers the amount of catalyst required for maximum conversion, resulting in lower quality biodiesel. To much water, and you wind up with "glop-soap" If you use an "open" style of processor you can see the reaction and can "tweak" it a little by the addition of extra catalyst thereby saving the batch.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
