I need some help, I think my t/c is stuck in full lock up. after I start my truck, soon as I put it in gear it stalls out. has anyone experienced this? Is
it controlled electronically? Any suggestions or comments? and if its bad, what is a good quality, best priced torque converter to buy? Thanks!
Try putting into reverse, but the moment you throw it into reverse let of the brake and give it some gas, just try to get the thing moving, if it does, then your torque converter is probably locked up.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
Electrical should flash the OD.
Check idle line pressure than cooler flow. (low)
If ok you have to check the TC solenoid for a leak/stuck.
If above is good then i would move to a new TC and seal.
Thats off the top of my head.
M.K. might have some input.
The Edge can't tell you line pressure. All it can tell you is what line pressure it wants. You have to measure line pressure with a 0-350 PSI gauge.
You could have a stuck torque converter control valve.
You could have a stuck torque converter control solenoid.
You could have low fluid.
You could have a loose/missing internal filter.
You could have low line pressure.
__________________ Mark
Former Ford automatic transmission engineer, 1988-2007.
